TS: Philips 346B1 34" curved-35k- Seldur
Oddy
Póstar: 868
Pósturaf Oddy » Fim 24. Apr 2025 13:02
Philips 346B1C UltraWide Curved LCD Monitor:
* Type: Curved UltraWide LCD Monitor
* Model: 346B1C/00
* Screen Size: 34 inches (86.36 cm)
* Panel Type: VA LCD
* Curvature: 1500R
* Aspect Ratio: 21:9
* Native Resolution: 3440 x 1440 (UltraWide QHD)
* Maximum Refresh Rate: 100 Hz
* Response Time (Typical): 4 ms (Gray to Gray) or 5 ms (GtG)
* Brightness: 300 cd/m²
* Contrast Ratio (Typical): 3,000:1
* SmartContrast: 80,000,000:1
* Viewing Angle (H/V): 178/178 degrees
* Display Colors: 16.7 million (8-bit)
* Color Gamut:
* 119% sRGB
* 100% NTSC
* 90% Adobe RGB
* Built-in Speakers: 5 W x 2
* Connectivity:
* 1 x DisplayPort 1.2
* 1 x HDMI 2.0
* 1 x USB-C 3.2 Gen 1 (upstream, power delivery up to 90W, DP Alt Mode)
* 1 x USB-B (upstream)
* 4 x USB-A (downstream)
* 1 x RJ45 (Ethernet)
* 1 x Headphone out (3.5 mm)
* Features:
* Built-in KVM switch
* MultiView (PIP/PBP mode, 2 devices)
* Adaptive Sync
* LowBlue Mode
* Flicker-free technology
* EasyRead mode
* Height adjustment (180 mm)
* Swivel (-180/+180 degrees)
* Tilt (-5/+30 degrees)
* VESA mount compatible (100 x 100 mm)
* Power Delivery (via USB-C): Up to 90W
* Manufactured: September 2019
This monitor is designed for productivity with its UltraWide display, USB-C docking capabilities, and built-in KVM switch. It also offers good image quality with its QHD resolution and wide color gamut.
Info tekknar frá Gemini.
Lítur vel út og virkar fínt. Ástæða sölu er að ég er eiginlega hættur í tölvum og þarf ekki svona skjá, konan vill ekki svona skjá. Tilboð óskast, staðsett á Akureyri
Verðhugmynd er 40k 35k
Seldur
Síðast breytt af Oddy á Fös 09. Maí 2025 15:53, breytt samtals 4 sinnum.
Oddy
Póstar: 868
Re: TS: Philips 346B1 34" curved
Pósturaf Oddy » Sun 27. Apr 2025 05:31
Ttt
Oddy
Póstar: 868
Re: TS: Philips 346B1 34" curved-40k
Pósturaf Oddy » Þri 29. Apr 2025 09:30
Ttt
Oddy
Póstar: 868
Re: TS: Philips 346B1 34" curved-35k
Pósturaf Oddy » Lau 03. Maí 2025 08:31
Ttt
Oddy
Póstar: 868
Pósturaf Oddy » Þri 06. Maí 2025 18:56
Ttt
