Að láta brýna eldhúshnífa
daremo
Póstar: 473
Pósturaf daremo » Mán 29. Ágú 2022 23:50
Vitið þið hvort það sé einhver hér á íslandi sem tekur að sér að brýna hnífa?
Eftir smá gúgl fann ég gamlan þráð á bland.is sem nefnir Brynju á Laugaveginum, en það hafa einhver eigandaskipti orðið síðan þá og ég treysti mér ekki alveg til að mæta þangað með dýru japönsku hnífana mína.
Er eitthvað í boði, eða þarf maður bara að læra þetta sjálfur og kaupa allar græjurnar?
Póstar: 8725
Re: Að láta brýna eldhúshnífa
Pósturaf rapport » Þri 30. Ágú 2022 00:37
Póstar: 6854
Pósturaf Viktor » Þri 30. Ágú 2022 08:07
Þetta eru nú engin geimvísindi :japsmile
https://byggtogbuid.is/catalogsearch/re ... ngarsteinn
Whetstones come in a range of grits:
- Less than 1000 grit is typically used to repair knives with chipped edges,
- 1000 to 3000 grit are used to sharpen dull knives,
- 4000 to 8000 grit are finishing stones and are used to refine your knife edge.
The #1000 grit stone is considered your basic, go to, sharpening stone. If your knives have lost their edge and need a good sharpen, then this is the grit you should start with.
You shouldn’t use this stone often, as it will wear your knife down. The #2000 and #3000 grit stones can be used more often if you are the sort of person who likes to sharpen a bit more regularly as they are less coarse, but again, they are designed for sharpening and not maintaining your edge.Once you get into a routine, you will get to know how often you need to use your medium stone.
NOTE: A little bit of advice we were given by a Chef; a #3000 grit whetstone is ideal for a boning knife and you don’t need to go any higher as refining your edge more will bend the knife on the muscle and sinew of the meat, meaning more frequent sharpening.
Síðast breytt af Viktor á Þri 30. Ágú 2022 08:10, breytt samtals 1 sinni.
sigurdur
Póstar: 242
Skráði sig: Lau 16. Jan 2010 12:37
Pósturaf sigurdur » Þri 30. Ágú 2022 09:36
Skerping á Smiðjuveginum. Þeir brýna allan fjandann þar.
Pandemic
Póstar: 3774
Pósturaf Pandemic » Þri 30. Ágú 2022 14:30
Handverkshúsið brýnir hnífa. Annars keypti ég svona græju sem þú dregur í gegnum í IKEA frá fiskars og það svínvirkar.
urban
Póstar: 3750
Pósturaf urban » Þri 30. Ágú 2022 15:39
Viktor skrifaði:Þetta eru nú engin geimvísindi :japsmile
Auðvelt líka að eyðileggja hnífa með því að halda þeim vitlaust á svona steinum.
Sumir eiga að vera í 15°aðrir í 18°og svo framvegis.
Það þarf stöðuga hendi og reynslu til að brýna dýra hnífa á svona steinum og gera það án þess að skemma þá.
dadik
Póstar: 670
Staðsetning: Reykjavik
Pósturaf dadik » Þri 30. Ágú 2022 17:52
ps5 ¦ zephyrus G14
Minuz1
Póstar: 1285
Pósturaf Minuz1 » Þri 30. Ágú 2022 18:11
Pandemic skrifaði:Handverkshúsið brýnir hnífa. Annars keypti ég svona græju sem þú dregur í gegnum í IKEA frá fiskars og það svínvirkar.
Kallast færeyingur.
https://brynja.is/vara/faereyjingur/
Minuz1
Póstar: 1285
Pósturaf Minuz1 » Þri 30. Ágú 2022 18:15
urban skrifaði:
Ég myndi fara varlega í það að kalla vitlaust brýndan hníf ónýtan, ég hef alveg lagað glataða hnífa sem hafði kvarnast úr vegna of skarprar eggjar. Það er alltaf hægt að laga þá nema þú brýtur blaðið.
Ég hef líka breytt tvískiptum hníf yfir í svona japanskan og aftur tilbaka.
Step 1 knifecare: honing steel.
Síðast breytt af Minuz1 á Þri 30. Ágú 2022 18:16, breytt samtals 2 sinnum.
urban
Póstar: 3750
Pósturaf urban » Þri 30. Ágú 2022 20:02
Minuz1 skrifaði:
urban skrifaði:
Tjahh jájá, hann getur alveg skorið áfram.
En ef að hnífur á að vera með eggina í 18° þá er hann ekki einsog hann á að vera ef að þú setur hana í 14°
Vissuelga alveg nothæfur hnífur áfram, en það er ekki sami hnífurinn og hann var.
Skiptir engu máli með ódýra hnífa en ég væri ekki sáttur við að fá 40 þús króna hníf úr brýningu öðruvísi en hann á að vera :)
Persónulega hefði ég samt meiri áhyggjur ef að eggin væri ekki eins, rokkandi frá 10°-20°er sáraeinfalt að gera með lausum steini.
Alveg vel hægt að brýna hnífa á steini, en það þarf meiri reynslu en að bara að kaupa stein og ætla að gera þetta sjálfur, allavega myndi ég sjálfur aldrei gera þetta við dýra hnífa fyrr en ég væri búin að læra tæknina vel og lengi.
Annars þurfa hnífar náttúrulega alls ekki að vera dýrir til að vera góðir.
Besti hnífurinn sem að ég hef komist í tæri við, sá sem að heldur endalaust biti og stálast frábærlega er hnífur úr pakka sem að kostaði 990 kr í IKEA :)
Síðast breytt af urban á Þri 30. Ágú 2022 20:05, breytt samtals 1 sinni.
MuffinMan
Póstar: 41
Skráði sig: Lau 03. Des 2016 21:55
Pósturaf MuffinMan » Mið 31. Ágú 2022 15:59
getur komið með þá hingað í Skerpu og ég get gert þetta fyrir þig þegar ekkert vesen
Nýja: 9900X3D. 4080 Super. Msi Arsenal. Lian li GAII 360mm. Gskill 96gb 6400. 9100 pro 2tb. 990pro 4tb.
Gamla: I7 4790K 4.6ghz. RTX 2080 Ti . Z97 Asus. Corsair 570x. Corsair H150I. SSD Samsung pro 2x raid 0. 2x hdd
daremo
Póstar: 473
Pósturaf daremo » Mið 31. Ágú 2022 23:33
urban skrifaði:Tjahh jájá, hann getur alveg skorið áfram.
Já þetta er akkúrat það sem ég hef áhyggjur af. Ég held að þessir hnífar þurfi að vera í 15°.
Hendurnar mínar henta alls ekki í svona nákvæmnisvinnu. Löngu búinn að skemma þær með óhóflegri músa og lyklaborðsnotkun :)
Takk fyrir svörin öllsömul. Það er greinilega fullt af úrræðum til.
