Til sölu eftirfarandi
Verð og nánari lýsing neðar í skjali. Spurningar og tilboð í PM, takk
- 6 stk - Dell PowerEdge R410 - 2cpu 12core 24threads - 12MB
- 4 stk - Dell PowerEdge R410 - 2cpu 12core 24threads - 16MB
- 5 stk - Dell PowerEdge R420 - 2cpu 12core 24threads - 24MB - iDRAC
- 8 stk - Dell Precision 5400 - 2cpu 8core 16threads
- 8 stk - Dell FX100 Zero Client
- 1 stk - Dell Powervault TL2000 - Tape Library
- 1 stk - Dell EqualLogic PS6000E Virtualized iSCSI SAN Storage Array
- 1 stk - Dell EqualLogic PS4000 Virtualized iSCSI SAN Storage Array
- 1 stk - Cisco WS-C2960X-48TS-L Catalyst 2960-X 48 GigE, 4 x 1G SFP, LAN Base
- 2 stk - Cisco Catalyst WS-C3750E-48PD-E 48x PoE Gbit + 2x X2-based 10Gbit Switch
> ISK 50.000.- stk
- PowerEdge R410 Rack Chassis, Up to 4x 3.5" Hot Plug HDDs, LCD Diagnostics, C2, TPM
- iDRAC6 Express
- 12GB Memory for 2CPU (6x2GB Dual Rank RDIMMs) 1333Mhz
- C7 Hot-Swap ASS No RAID for SAS 6/iR, Min. 1 Max. 4 SAS/SATA Hot Plug Drives
- 1U Rack Bezel
- Non-Redundant Power Supply (1 PSU) 480W
- 500GB, SATA, 3.5-in, 7.2K RPM Hard Drive (Hot-plug)
- 16X DVD-ROM Drive SATA with SATA Cable
- Intel Xeon X5650 Processor (2.66GHz, 6C, 12M Cache, 6.40 GT/s QPI, 95W TDP, Turbo, HT), DDR3-1333MHz
- Additional Intel Xeon X5650 Processor (2.66Ghz, 6C, 12M Cache, 6.40 GT/s QPI, 95W TDP, Turbo, HT)
> ISK 60.000.- stk
- Base,Server, Server Chassis PER410
- Chassis,Hot Plug HD,Tru sted Platform Module,R410,V2
- Hard Drive,500GB,3.5IN S2,Hitachi,Gemini
- Cable,Interface Motherboard,Optical Device Drive,R410
- Media,Digital Video Disk Drive,Document Object Model,PER410
- Processor,X5650,2.66,12 MB,Xeon Westmere Efficient Per formance,B1
- Processor,X5650,2.66,Xe on Westmere Efficient Performa nce,B1,Second
- Module,Power Supply,SINGLE 480W,Delta Products
- Module,Cable,Serial Attached Scsi,6IR,Modular,Hot Plug,HDD
- Module,Dual In-Line Memory Mod ule,16G,2R,4X4G,Registered Dim m
- Module,Card,Controller Serial Attached,Scsi,SAS6IR Daughter,ESG
- Module,Thermal,Server,Chassis PER410,DUAL-PRC
- Module,Digital Video Disk Driv e,Serial Ata,12.7,Teac,E
> ISK 120.000.- stk
- PowerEdge R420 TPM
- PERC H710 Integrated RAID Cont roller, 512MB NV Cache
- 300GB, SAS 6Gbps, 2.5-in, 10K RPM Hard Drive (Hot-plug)
- VFlash, 8GB SD Card for iDRAC Enterprise
- Intel Xeon E5-2420 1.90GHz, 15M Cache, 7.2GT/s QPI, Turbo, 6C, 95W
- Intel Xeon E5-2420 1.90GHz, 15 M Cache, 7.2GT/s QPI, Turbo, 6 C, 95W
- 4x 8GB Memory for 1CPU (1x8GB Dua l Rank LV RDIMMs) 1600MHz
- Chassis with up to 8, 2.5" Hot Plug Hard Drives
- PCIE Riser for Chassis with 2 Proc
- Power Distribution Board for H ot Plug Power Supplies
- iDRAC Port Card
- Dual Hot Plug Power Supplies 550W
- No Internal Optical Drive
> ISK 20.000.- (+40k incl FX100)
- Base,rack mounted 2U,Xeon Dual Processor Harpertown,E5410,R5400
- Module,Card,Graphics,RHA,FX100
- Module,Processor,Second,Xeon Dual Processor Harpertown E5410,R5400
- Module,Hard Drive,500,S2,1 HIT-SATURN,RCK
- Module,Media,Digital Video Disk Drive,Resource Dvd,T7400 T5400
- Module,Dual In-line Memory Module,8G,4X2G,667,2R,Error Correction Code
- Module,Dvd+/-rw,8X,2U,Hitachi Lg Data Storage,Precision Workstation
> ISK 40.000.- stk
Already inside the Precision 4500 - can be sold separately - Host card + access device
https://www.dell.com/downloads/global/p ... csheet.pdf
- PCIe x1 card for host workstation
- 2 DVI-I ports
- 1 RJ45 jack for 10/100/1000 Mbps Ethernet
> ISK 170.000.- stk
- PowerVault TL2000 Tape Library , 2U, 24 Slot, 1 or 2 Drives
- LTO-6 SAS Tape Drive
- 4x LTO-6 Media 5 PK
- LTO Tape Cleaning Cartridge - Includes Barcode
- 6Gbps SAS HBA Card
> ISK 450.000.- stk
- Dell EqualLogic PS6000E SATA 7.2K, EUC - EM
- 16TB Capacity, 16 x 1TB SATA 7.2K HD, Dual Controller
> ISK 350.000.- stk
- EqualLogic PS4000E SATA 7.2K, EUC - EM
- PS4000E 8 X 1TB SATA 2 Controllers
> ISK 100.000.- stk
Already connected - can be separated and sold individually
> ISK 150.000.- stk
[TS] Servers - Workstations - Tape - Storage Array - Switches ofl.
Síðast breytt af bobbyb á Fös 13. Sep 2019 20:25, breytt samtals 1 sinni.
Re: [TS] Servers - Workstations - Tape - Storage Array - Switches ofl.
Upp!
enn er eitthvað til af þessum búnaði
Mossi__
- vélbúnaðarpervert
- Póstar: 922
- Skráði sig: Þri 21. Nóv 2017 22:49
Daginn.
Er listinn up to date?
ekki 100% en næstum - hafa verið einhverjar hreyfingar og eitthvað að bætast við.
