Er með HP ZR2740w skjá til sölu. Hann er mjög lítið notaður og sér ekki á honum.
Listaverð á svona skjá fyrir um 3 árum síðan var um 170þ.
Ég set á hann 50þ en er tilbúinn að skoða öll tilboð.
http://h20564.www2.hp.com/hpsc/doc/public/display?docLocale=en_US&docId=emr_na-c02974762
Nánari upplýsingar um skjáinn hér að neðan:
Physical specifications
Specification
Description
Dimensions (H x W x D)
Unpacked with stand:
44 to 54 x 64.6 x 23.5 cm (17.3 to 21.26 x 25.4 x 9.3 in)
Unpacked without stand (head only):
39.2 x 64.6 x 6.8 cm (15.4 x 25.4 x 2.7 in)
Packaged:
75.5 x 35.5 x 48.0 cm (29.7 x 14 x 18.9 in)
Base area (footprint):
33.4 x 23.5 cm (13.1 x 9.3 in)
Weight
Head only:
8 kg (17.6 lb)
Unpacked:
10.5 kg (23.1 lb)
Packaged:
13.5 kg (29.5 lb)
Tilt range
-5° to +30°
Swivel range
Yes (+/- 45°)
Height adjustable
Yes (10 cm)
Pivot rotation
Yes
top
Panel specifications
Feature
Description
Type
In-Plane Switching (IPS) LED Backlit LCD
Viewable image area (diagonal)
68.5 cm (27 in) widescreen; diagonally measured
Screen opening (H x W)
59.8 x 33.6 cm (23.5 x 13.3 in)
Optimal resolution
2560 x 1440 @ 60 Hz; 3.7 MP
Aspect ratio
16:9 widescreen
Viewing angle (typical)
Up to 178° horizontal/178° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
380 nits (cd/m²)
Contrast ratio (typical)1
1000:1
Response time (typical)1
12 ms (gray to gray); 14 ms (On/Off)
Pixel pitch
0.2331 mm
Backlight lamp life (to half brightness)
39,000 hours minimum
Color gamut (typical)
72%
Color support2
Up to 1.07 billion colors
NOTE: 1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
2: Display of up to 1.07 billion colors on ZR2740w requires use of display port input with 10-bit content.
top
On Screen Display (OSD) controls specifications
Specification
Description
Buttons or switches
Source, Minus, Plus, Power On/Off
Languages
Not applicable
User controls
Brightness, Source
top
Signal interface/performance specifications
Specification
Description
Horizontal frequency
90 kHz
Vertical frequency
60 Hz
Native resolution
Preset VESA graphic modes (non-interlaced)
2560 x 1440 @ 60 Hz
Maximum pixel clock speed
250 MHz
User programmable modes
None
Anti-glare
Yes
Default color temperature
6500 K
top
Video/other inputs specifications
Specification
Description
Plug and play
Yes
USB 2.0 hub
One upstream, four downstream ports (cable included)
Input connectors
(1) Display port connector; (1) Dual-Link DVI connector, HDCP support on display port and DVI
Video cable
Display port, dual-link DVI-D
Video cable lengths
1.8 m (5.9 ft)
Audio
No
SELT [TS] HP 27" Z-skjár - SELT
JoiAxels
Höfundur - Græningi
- Póstar: 47
- Skráði sig: Fös 23. Sep 2011 00:25
Síðast breytt af JoiAxels á Mið 27. Júl 2016 17:55, breytt samtals 1 sinni.
