HDMI color mode
svanur08
Póstar: 2655
HDMI color mode
Pósturaf svanur08 » Þri 05. Feb 2013 14:36
Hvaða HDMI color mode er best í blu-ray spilara?
YCbCr (4:4:4)
YCbCr (4:2:2)
RGB (Standard)
RGB (Enhanced)
Póstar: 6853
Re: HDMI color mode
Pósturaf Viktor » Þri 05. Feb 2013 15:15
http://www.audioholics.com/tweaks/calib ... -xvycc-rgb
Virðist vera ansi flókið.
Simplifying the Process - What to Do
Luckily for us - the net result is that these settings aren't all that hard to get right after all. Here are a few things to keep in mind, however:
Standard definition DVDs, Blu-ray discs and HD signals are all YCbCr 16-235 range native. Always set your source to YCbCr mode (not RGB) when calibrating your black and white levels on your display.
Some AV receivers may not pass anything except 16-235 via HDMI. This means that if you are setting your source to RGB (0-255) you may get your black and white levels truncated.
xvYCC is significant ONLY if all components in the chain support xvYCC. Do not utilize this setting on any component unless everything else can fall into place. Once set, xvYCC should override and RGB or YCbCr settings.
svanur08
Póstar: 2655
Re: HDMI color mode
Pósturaf svanur08 » Þri 05. Feb 2013 16:39
Sallarólegur skrifaði:http://www.audioholics.com/tweaks/calibrate-your-system/hdmi-black-levels-xvycc-rgb
Það er default á ---> YCbCr (4:4:4) á spilaranum mínum.
