GEFINS - 21" Professional HP P1100 CRT
izelord
Póstar: 181
Skráði sig: Þri 24. Sep 2002 17:29
Staðsetning: Hafnarfjörður
Pósturaf izelord » Fös 30. Sep 2011 12:12
Þessi elska fæst gefins. Hefur verið lítið notuð undanfarin ár og passar ekki lengur inn í innanhúsarkítektúrinn minn. Virkar auðvitað.
http://www.dooyoo.co.uk/crt-monitor/hp-p1100/details/:
Description:Model ID D2846A#ABD / HP P1100 - Display - CRT - 21" - 1600 x 1200 / 85 Hz - 0.25 mm - VGA (HD-15) - white / The Hewlett-Packard HP P1100 monitor is a great choice for professional users who run high-end business and design applications that require more workspace, sharper picture ... more
HP P1100 ... and higher refresh rates. Hewlett-Packard monitors are optimized to run on HP CPUs, but are also suitable for other branded computer systems. This 21-inch color monitor supports a 1600x1200 high resolution at a flicker-free 85 Hz refresh rates. The 19.8-inch viewable area screen features a Trinitron-based aperture grill CRT with a .25 mm AG pitch. It's matched with an antireflective, antistatic coating to yield high-end crisp, bright contrasted images. This combination of features produces the sharp, clear images required for advanced applications. The on-screen display with digital controls uses an illustrated approach for easy and precise picture adjustments, including color level, color temperature, tilt, zoom, and geometry controls. The P1100 is plug and play compatible for optimal performance and ease of setup under Windows 95. It meets strict TCO'95 standards for power management and emissions level standards for safer long-term viewing.
Display Type Display / CRT
Width 49.8 cm
Depth 47.4 cm
Height 50.4 cm
Weight 31 kg
Enclosure Colour White
Localisation German / Germany
Display
Diagonal Size 21"
Viewable Size 19.8"
Dot Pitch / Pixel Pitch 0.25 mm
Max Resolution 1600 x 1200 / 85 Hz
Max Sync Rate (V x H) 160 Hz x 107 kHz
Factory Preset Resolution Modes 800 x 600 / 85 Hz
800 x 600 / 75 Hz
800 x 600 / 60 Hz
800 x 600 / 160 Hz
640 x 480 / 85 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
640 x 480 / 160 Hz
1600 x 1200 / 75 Hz
1600 x 1200 / 60 Hz
1600 x 1200 / 85 Hz
1280 x 1024 / 85 Hz
1280 x 1024 / 75 Hz
1280 x 1024 / 60 Hz
1280 x 1024 / 98 Hz
1024 x 768 / 85 Hz
1024 x 768 / 75 Hz
1024 x 768 / 60 Hz
1024 x 768 / 129 Hz
Front Panel Controls Power on/off, adjust +/- , select
On-Screen Controls Contrast, brightness, H/V-position, H/V-size, pincushion distortion, H/V-moire, degauss, trapezoid, parallelogram, recall settings, colour temperature selection, convergence, rotation
Video Input
Analogue video Signal RGB
Expansion / Connectivity
Connections 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) - 1
Miscellaneous
Cables Included 1 x display cable
Compliant Standards Plug and Play, FCC Class B certified, CE, CSA, UL, TUV GS, CISPR 22 Class B, DDC-1, DDC-2B, DHHS, EN 60950, EN55022, EPA Energy Star, IAA, IEC950, ISO 9241, MPR III, NEMKO, NOM, NUTEK, PTB, SEMKO, TCO '95, VCCI-II, ZH1 618
Power
Form Factor Integrated
Voltage Required AC 110/220 V ± 20% ( 47/63 Hz )
Power Consumption Operational 160 Watt
Power Consumption Stand by / Sleep 15 Watt
