Onkyo TX-606 Heimabíómagnari til sölu [SELT]
Televisionary
Póstar: 751
Pósturaf Televisionary » Þri 02. Ágú 2011 22:54
Framhlið:
Bakhliðin:
Ég sótti upplýsingarnar um tækið af heimasíðu framleiðandans. Það sér ekki á þessum grip og hann hefur einungis verið notaður sem steríó magnari. Hann var keyptur árið 2008 í UK.
Þetta er tæki sem hefur reynst mér vel en nú er áætlað að kaupa nýjan búnað.
Technical Details
Features
ADVANCED FEATURES
• DTS-HD Master Audio, DTS-HD High Resolution Audio, Dolby TrueHD, Dolby Digital Plus Decoding
• HDMI 1.3a* Audio and Video Processing (1080p; 4 Inputs and 1 Output)
• HDMI Video Upscaling (to 1080i) from Component-Video, S-Video and Composite Video Inputs.
• RIHD (Remote Interactive over HDMI) for System Control
• HDTV-Capable HDMI Switching
• Deinterlacer with Faroudja DCDi Edge™ (Directional Correlational Deinterlacing) Technology
• Audyssey 2EQ to Correct Room Acoustic Problems and to Calibrate Speakers
• Audyssey Dynamic EQ for Loudness Correction
• Bi-Amping Capability for Music and Movie Surround Effects
• Compatible with RI (Remote Interactive) Dock for the iPod
*Supports Deep Color
AUDIO FEATURES
• 90 W/Ch Minimum into 8 Ohms, 1 kHz, IEC (1 Channel Driven)
• DTS®-ES™ Discrete/Matrix, DTS® Neo:6, DTS® 96/24, Dolby® Digital EX™, Dolby® Pro Logic® IIx Decoding
• H.C.P.S. (High Current Power Supply) Massive High Power Transformer
• 192 kHz/24-Bit DACs for All Channels
• HDTV-Capable (to 720p/1080i) Component Video Switching (2 Inputs and 1 Output)
• WRAT (Wide Range Amplifier Technology)
• Advanced 32-Bit Processing DSP Chip
• 4 Digital Inputs (2 Optical/2 Coaxial)
• Subwoofer Pre Out
• CinemaFILTER™
• Pure Audio Mode
• Direct Mode
• A-Form Listening Mode Memory
• Optimum Gain Volume Circuitry
• Music Optimizer for Compressed Music Files
• Non-Scaling Configuration
• Tone Control (Bass/Treble) for Front L/R Channels
• Color-Coded 7.1-Multichannel Inputs
• Independent Crossover Adjustment for F/C/S/SB (40/50/60/80/100/120/150/200 Hz)
• Double Bass Function
OTHER FEATURES
• Powered Zone 2 and Zone 2 Line-Out for Playback in Another Room (Separate Source)
• Dual Banana Plug-Compatible Speaker Posts for All Channels
• A/V Synchronization Function (Up to 100 ms in 10 ms Steps)
• 40 FM/AM Radio Presets
• RDS (PS/RT/PTY/TP)
• 4 S-Video Inputs and 2 Outputs
• 5 A/V Inputs and 1 Output
• 2 Audio Inputs and 1 Output
• Digital Upsampling
• Display Dimmer (Normal/Dim/Dimmer)
• Headphone Jack
• Sleep Timer (via Remote)
• Battery-Free Memory Backup
• Aluminum Front Panel
Selst hæstbjóðanda
Áskil mér þann rétt að hætta við söluna ef ég tel viðunandi boð ekki nást. Sendið EP hérna eða á stuff hja mulinn.net
Síðast breytt af Televisionary á Sun 21. Ágú 2011 14:42, breytt samtals 3 sinnum.
Televisionary
Póstar: 751
Re: Onkyo TX-606 Heimabíómagnari til sölu
Pósturaf Televisionary » Fös 05. Ágú 2011 10:01
Upp.
mundivalur
Póstar: 2327
Staðsetning: South side
Pósturaf mundivalur » Fös 05. Ágú 2011 10:12
Verð hugmynd?
Televisionary
Póstar: 751
Pósturaf Televisionary » Fös 05. Ágú 2011 11:12
Selst hæstbjóðanda
Það er komið boð uppá 20 þúsund en hann verður ekki seldur fyrir þá upphæð. Ef ég man rétt kostaði hann um 400 pund árið 2008. Ef viðunandi boð fæst ekki þá endar hann í bílskúrnum.
mundivalur skrifaði:Verð hugmynd?
Televisionary
Póstar: 751
Pósturaf Televisionary » Lau 06. Ágú 2011 21:49
Komið tilboð uppá 35 þúsund krónur frá notandanum [Steini B].
Televisionary
Póstar: 751
Pósturaf Televisionary » Fim 11. Ágú 2011 13:27
Upp í síðasta skipti.
SIKO
Póstar: 209
Skráði sig: Mið 14. Jan 2004 23:23
Pósturaf SIKO » Sun 14. Ágú 2011 10:01
ég bíð 45 þús.. ef það er klárað í dag.. 8468118 kv þórður
I Mac 24" 2.8ghz, 4gb ddr800 1TB, ATI Raedon HD... of fullt af öðru drasli....
www.sikoairbrushing.com...
sprauta tölvur líka :)
