ég var að lesa á overclock.net review um i7 970 sem var að koma frá intel en þetta er 6kjarna örri sem er talin vera "normal" útgáfan af 980x eða ekki extreme. þetta er overclocking monster!!
Þetta er btw á lofti (Noctua NH-D14)
og eftir að hafa haft meiri tíma bættu þér þetta með sömu kælingu:
Overclocking was a complete joy. Being unable to adjust the multiplier upwards normally means a lessened overclock because maintaining a high stable BCLK isn't as easy as increasing the multiplier. However any doubts about the headroom available were quickly swept away as we saw first 4.7 GHz and finally 4.8 GHz. On air. Even then the temperatures didn't go above 78°C, so with a more exotic cooling solution the 5 GHz barrier should be easily obtainable. With a reduction in the overclock to keep it all under control throughout our gamut of tests we still had it perfectly stable at an incredible 4.3 GHz.
mér langar í þennan! veit eitthver um verðhugmynd á þessum þegar hann kemur til landsins
](./images/smilies/eusa_wall.gif)
