A disk read error occurred
hsm
Póstar: 921
Staðsetning: Keflavík
Pósturaf hsm » Þri 22. Apr 2008 14:10
Þegar þessi skilaboð koma upp er ég kveiki á fartölvunni "A disk read error occurred""Press Ctrl+Alt+Del to restart"
Er þá harði diskurinn bilaður :?
Er búinn að fara í biosinn og hún finnur diskinn og ég get gert test á honum sem virðist vera í lagi EN..
Ef einhver veit hvað ég á að byrja á að gera þá endilega.
Póstar: 5677
Staðsetning: ;)
Re: A disk read error occurred
Pósturaf Gúrú » Þri 22. Apr 2008 15:02
http://www.hardwareanalysis.com/content ... 9004/?o=20
Gæji af microsoft forums skrifaði:For those of you having this problem, Here's your answer. Those of you have different brand computers, need to get into the BIOS. First, when you first turn on the computer, the post boot screen will come on, look for where it will tell you what key to press to get into the BIOS. All systems are different, some are done by pressing the F2 key, or the F11 key, others are the DEL key. On Compaqs and HP, uses the F11 key, Dells and other systems uses the F2 key. Barebone systems uses the DEL key. Once you are in the BIOS, you need to find the section on the Boot Order. The boot order should be placed in the following order:
1. HDD (Hard Disk Drive)
2. CD-ROM
3. FDD or NET or the like. (The 3rd boot order can also be disabled by selecting it.)
Make sure the the HDD is placed as the first boot priority before any others in the listing, which means your main hard drive must be placed as a first boot device before any others that is listed. Also be sure that the black jumper in the back of your main hard drive is set to MASTER or MA as abbreviated according to the schematics shown on top of your hard drive. Any other drives that you have such as your CD-ROM, DVD-ROM must be placed as SLAVE or SL as abbreviated on the back of them. Once you have the boot priority set, hit the ESC key and save the configuration. It should now boot to your main hard drive booting up your Windows. Also, make sure your CD is out of your CD-ROM drive or the DVD-ROM drive! Good luck. Any other questions, I will be on a stand by.
Googlaði þetta bara :/
Modus ponens
Allinn
Póstar: 459
Skráði sig: Fim 17. Apr 2008 18:22
Pósturaf Allinn » Þri 22. Apr 2008 15:16
Þetta hlýtur að vera vandamál með C drif þú verður að fara í BIOS og í Boot from ,Your HDD,
hsm
Póstar: 921
Pósturaf hsm » Þri 22. Apr 2008 16:55
Allinn skrifaði:Þetta hlýtur að vera vandamál með C drif þú verður að fara í BIOS og í Boot from ,Your HDD,
Ég er með HP Compaq nx8220 og er búinn að fara í BIOS og fikta þar.
Það er u.þ.b. 1ár síðan ég setti þennan harða disk í vélina og það hefur verið í fínu lagi með tölvuna alla daga síðan,
nema þetta byrjaði í firradag.
Ég er með HDD valið sem fyrsta boot í BIOS
Ætla að prufa að taka hann úr og setja hann í flakkarann minn og a.t.h. hvort að hann virki þar.
Viðbót:
1. Er búinn að taka diskinn úr og setja hann í flakkarann og virðist alveg virka fínt.
2. Er búinn að setja annan disk í fartölvuna og þá kemur ekki sama error. Hann er reyndar ekki með windows uppsettu en ég byrjaði uppsetningar ferlið og það virtist virka.
3. Svo prófaði ég að setja sama diskin í og þá kom bara aftur sama error skilaboð.
Þannig að er ekki líklega að HDD sé með einhvern galla kanski á BOOT Sector eða eitthvað álíka ??
