Sapphire Radeon HD X2900XT
Skjákort - PCI-E - ATI - X2900XT 512MB GDDR3 HDMI PCI-E
Chipset : ATI Radeon HD 2900 XT
System Interface : PCI- Express x16
CLK/MLK : 740MHz/ 1650MHz
Memory Size : DDR3 512MB / 512- bit
RAMDAC : 400MHz
Connector : HDTV, dual DVI- I DVI w/HDCP (HDMI adaptor)
Highlight
- ADEON HD X2900XT GPU
- esigned to run perfectly with the next- generation PCI Express bus architecture. This new bus doubles the bandwidth of AGP 8X delivering over 4 GB/sec. in both upstream and downstream data transfers
- ntegrated with 16- Channel 512- bit 512MB DDR3 memory (1650MHz Effective! )
- ossless Z Compression & Fast Z- Buffer Clear
- ierarchical Z- buffer with Early Z test
- upport for Microsoft DirectX?10 & Shader Model4.0
Driver & Support
- indows 98 / ME / 2000 / XP / Vista
- inux Compatible
- icrosoft DirectX?10 Compatible
- upport for OpenGL?2.0
Main Features
- ultiply- Add- rate to 475GFlops 7.5 Gigapixels/sec Pixel Processing Rate
- p to 320 Stream processing units 06 GB per second Memory Bandwidth
- ully associative texture, color, and Z/stencil cache designs
- omplete feature set also supported in OpenGL?2.0
- ccelerated MPEG- 2, MPEG- 4, DivX, WMV9, VC- 1, and H.264 decoding and transcoding
- otion compensation, IDCT, DCT and color space conversion
- ull speed 521- bit floating point processing for all shader operations
- edicated branch execution units for high performance dynamic branching and flow control
Opening up the box we find the following items:
The HD2900XT
One crossfire bridge
Two DVI => VGA adapters
One DVI => HDMI adapter
One component video-out cable
One composite/svideo video-out cable
Two Molex => PCI-E 6-pin adapters
The manual
CD with drivers
Voucher for Valves Black Box (Half File 2: Episode 2, Team Fortress 2, Portal) for download from Steam.
512MB 512-bit GDDR3 PCI-Express
Nýjasta kortið frá ATI sem inniheldur byltingakenda tækni og eru margir að veðja á að með endurbættum reklum verði þetta kort jafnvel öflugra en 8800GTX. Þrátt fyrir þetta er það á mun lægra verði. Frábær kaup fyrir framsýna leikjaspilara.
kr. 41.500
Væntanlegt
Upplýsingar Tegundarlýsing
Framleiðandi Sapphire
Tæknilegar upplýsingar
Heiti kjarna Radeon HD X2900XT
Klukkuhraði kjarna
740MHz
Fjöldi pípa
(320 Stream processors)
Breidd minnisbrautar
512-bit
Tengiviðmót
PCI-Express 16X
Minnishraði
1650MHz
Minnisstærð
512MB
Tengimöguleikar
Sjónvarpstengi HDTV/S-Video out
DVI
Inno3d GeForce 8800Ultra
Specification:
Product Inno3D Geforce 8800 Ultra
Chipset Geforce 8800 Ultra
Memory 768MB GDDR3
Core Frequency 640MHz
Memory Frequency 2160MHz
RAMDAC
400MHZ
Interface
PCI-Express
Memory Bus
384-bit
Stream Processors 128
Max. Resolution
2560 x 1600
SLI Ready
Yes
Output
1. Dual-Link DVI
2. HDTV
HDCP Yes
Redefine your gaming reality with NVIDIA® SLI™-Ready GeForce® 8800 graphics processors. The world’s first DirectX® 10 GPUs feature a powerful unified architecture that delivers an incredibly true-to-life gaming experience. Power through games at record speeds. Charge through game maps with vividly realistic, sun-up to sun-down HDR lighting effects. And crank up 16x full-screen anti-aliasing without missing a beat.
Product Requirement:
1. A PCI-Express compliant motherboard with full size expension slot
2. 2 x 6-pin PCI Express supplementary power connector
3. Minimum 450W or greater system power supply (with 12V current rating of 30A)
Package Contents:
Accessories 1. DVI Dongle x 2
2. HDTV Cable
Software Bundled 1. PC Game x 1
Eitt öflugasta kortið sem fáanlegt er í veröldinni. Með 128 streymi-örgjörvum sem eru klukkaðir á 640MHz og með minnisbandbreidd upp á 109,44GB/s þá er fátt sem kemst nálægt afkastagetu þessa skrýmslis.
Athugið að um sérpöntun er að ræða.
kr. 67.500
Sérpanta
Framleiðandi Inno3d
Framleiðsluheiti I-8800U-k5JTCSX
Klukkuhraði kjarna
640MHz
Fjöldi pípa
(128 stream processors)
Heiti kjarna GeForce 8800Ultra
Minnisstærð
768MB
384-bita
Minnishraði
2280MHz
Tengiviðmót
Til eru þrenns konar tengiviðmót fyrir skjákort:
* PCI-express er nýjast og er notað af flestum nýrri skjákortum. Passar ekki nema á móðurborð með PCI-express rauf
* AGP er gamli skjákortastaðallinn, hann er óðum að hverfa af sjónarsviðinu. Passar ekki nema á móðurborð með AGP-rauf
* PCI er hin hefðbundni tengistaðall sem flestar tölvur nota enn í dag, þó er hann sjaldnast notaður fyrir skjákort þar sem hann er mun hægari en hinir tveir ofangreindu.
PCI-Express 16X
Tengimöguleikar
DVI
DVI eða Digital video interface eru ný stafræn tengi fyrir skjái sem margir LCD skjáir nota.
2
hvort munduð þið kaupa ? ati kortið er samnt 26 þús kr ódýrara
það sem inn0 3d hefur yfir það er Minnisstærð og Minnishraði skiptir það öllu máli eða ???
ok ultra tók þetta í rassgatið
