[TS] S.M.S.L SD793-II Headphone Amp
peer2peer
Póstar: 1123
Staðsetning: Seltjarnarnes
Pósturaf peer2peer » Fös 04. Mar 2022 18:31
SMSL SD-793II decoder uses the advanced digital receiver chip DIR9001, it can receive 24bit/96K signals at the highest. DAC adapt the one of the best D/A decode PCM1793 chip(192K/24Bit convert chip). Use active low pass filteroutput (sealed pack OPA2134, user an change this IC to adjust sound).
SMSL SD-793II decoder can work with coaxial and optical jacks on computer LCD, TV, CD, DVD, MD.
Specification:
Input interface: coaxial or optical fiber(with switch)
Input frequency:44.1, 48, 96KHZ/16/24BIT
SNR: > 113dB
Dynamic range: 105dB
Distortion: 1KHZ% under 0.0006
Rated output: 1.7VPP
Frequency response: 20 - 20KHz( - 0.2dB)
Total output power: < 8W
Headphone output power: 65mW @ 16Ω; 130mW @ 32Ω
Headphone output distortion: 0.01% THD + N @ 100mW/32Ω
Þrusu öflugur headphone magnari með optical out og rca.
6.000kr
peer2peer
Póstar: 1123
Re: [TS] S.M.S.L SD793-II Headphone Amp
Pósturaf peer2peer » Þri 08. Mar 2022 14:21
Topp, viltu ekki betra sound með heyrnartólunum þínum?
peer2peer
Póstar: 1123
Pósturaf peer2peer » Mið 01. Feb 2023 18:30
Upp með þetta aftur
