DLS ULTIMATE Nobelium 12i
Size 30 cm (12")
Impedance 2 x4 ohm
Nom. power (RMS) 600 W (max 1000)
Freq. range 20 Hz - 2,5 kHz
Voice coil, diameter 75 mm (3”)
Voice coil, length 40 mm (1,57”)
X-max +-14 mm (0,55”)
Cms 143
SD 510 cm
2
Cone material Aluminium
Magnet weight 180 oz (5,1 kg)
Magnet, diameter 220mm (8,7”)
Installation depth 153 mm (6”)
Mounting hole 282 mm (11,1”)
Outer diameter 313 mm ( 12,32”)
Weigth 12,7 kg (28 lbs)
T/S-Parameters Fs 30,2 Hz Re 1,8 Ohm Qms 4,17
(in parallel) Vas 58,8 liter Vas 2,08 Cuft Qes 0,46
Qts 0,41 Sd 531 cm? BL 11,85
