móðurborð fyrir mobile örgjörva ?
ponzer
Póstar: 1271
Skráði sig: Þri 07. Sep 2004 18:18
Staðsetning: Router(config)#
Pósturaf ponzer » Mán 14. Mar 2005 00:34
Er með svona http://processorfinder.intel.com/scripts/details.asp?sSpec=SL6F9 örgjörva, hann var í laptop vél en ég tók hann úr henni. Þannig mig langar að vita hvort það er hægt að kaupa móðurborð fyrir svona örgjörva (ekki lappa móðurborð heldur venjulegt). Package Type - 478 pin PPGA FC-PGA2, er þetta kannski s478 örri :?: :? .
ponzer
Póstar: 1271
Pósturaf ponzer » Mán 14. Mar 2005 00:39
Verið að tala um þetta http://gathering.tweakers.net/forum/list_messages/879704/ hérna en þetta er á einnhverju hrognamáli :(
kristjanm
Póstar: 1196
Skráði sig: Sun 20. Jún 2004 23:07
Pósturaf kristjanm » Mán 14. Mar 2005 07:32
Ég held að þú þurfir móðurborð með Pentium M chipsetti fyrir þetta.
Til eru móðurborð með i855 fyrir Pentium M frá Aopen og DFI en ég veit ekki hvort þau fáist á Íslandi.
gnarr
Póstar: 6600
Pósturaf gnarr » Mán 14. Mar 2005 08:06
Introduction
Intel plans to release Prescott with 0,90 nm process end of 2003 with 200 MHz FSB. Not to mention their latest plans for the Northwood itself. They have skipped the 667MHz BUS altogether and have gone way ahead to 800MHz BUS or rather for our article's sake, Quad Pumped 200MHz. But little do people know that the CPUs today can also reach this FSB. Without the need for special Liquid Nitrogen cooling or Prometeia cooling as already done by Pilsy and Macci from 3DMarks fame. We have here a CPU that anyone can use to run at 200MHz FSB with normal Air-cooling.
Requirements
What do u need ?
A P4 Mobile CPU
So what is so special about the P4 Mobile CPU? First of all the P4 Mobile are normal Northwoods but built to run at a lower Vcore and built to produce less heat. Therefore it can be said that they are specially-selected Northwoods. This would give rise to the chance of a wonder chip being found. Because they perform the same as a normal Northwood, but yet they have to run at a lower core voltage, it tends to reason then that the core on these Mobile Northwoods would almost definitely be selected from the middle of a Wafer to obtain the best of Silicon. Having read this far, most users not new to overclocking would have already picked up that you would be able to reach higher speeds with these selected Processors or have them at normal speed with much less Voltage. However, I do realize sometimes that numbers or rather figures speak louder than words so have a look at this link and note the Wattage and Vcore and Thermal Design Power and Thermal Specifications =).
Rather than bore you with all technical aspects of the P4 Mobile CPU, we'd concentrate more on the more general details. For those who feel more challenged and would like to know more about the Mobile CPUs you can do so at this link The gist of it is that they have a normal "optimized" Vcore of 1.2 Volts (With Battery power) and a Vcore of 1.3 Volts for performance optimized via AC power. This information would be the most useful to yourself as you definitely do not want to put too much Vcore into this CPU without knowing what it is Spec(ed) at.
When u insert a mobile CPU into a normal Motherboard, the board's BIOs should default to the use of 1.5 Volts, as per a normal Northwood. Some Boards do have voltages as low as 1.1Volts should the need arise for you to run it at stock which you should see why in a moment.
So What is different about the Mobile CPU as compared to the normal Northwood?
Since we've already stated what happens when you put one of the Mobile CPUs into a Desktop Board, you'd have by now no doubt guess that the CPU is pin compatible with the normal P4 Northwood (Socket 478). What is different however is the packaging of the CPUs.
efsta síðan sem kom upp á google hjá mér..
http://www.google.com/search?hl=is&q=P4m+desktop&lr=
http://www.vr-zone.com/guides/Intel/P4M/
ponzer
Póstar: 1271
Pósturaf ponzer » Mán 14. Mar 2005 08:22
Ég var búinn að Googla þetta í langan tíma en fann ekki mikið :? . Svo að þetta ætti að passa í normal s478 móðurborð :D
En skiptir einnhverjum máli hvaða chipset ég nota ?
