er diskurinn að fara að deyja ?
kubbur
Póstar: 1399
Pósturaf kubbur » Lau 28. Jan 2012 02:21
jæja, ég tók eftir því að ég komst ekki inná ákveðinn folder á servernum, fattaði svo að þetta var eini folderinn sem er shaeraður á sdb svo ég restartaði því ég komst ekki inná diskinn, komst inná hann eftir að ég restartaði og fór svo og tékkaði í syslog og brá heldur betur þegar ég sá þetta
Jan 27 06:25:16 kubbur-server kernel: [883984.163665] EXT4-fs (sdb1): previous I/O error to superblock detected
Jan 27 06:25:16 kubbur-server kernel: [883984.163733] Buffer I/O error on device sdb1, logical block 0
kubbur@kubbur-server:~$ sudo smartctl --all /dev/sdb
smartctl 5.41 2011-06-09 r3365 [i686-linux-3.0.0-12-generic-pae] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Caviar Green
Device Model:     WDC WD10EACS-14ZJB0
Serial Number:    WD-WCASJ1978100
LU WWN Device Id: 5 0014ee 2ac9a5630
Firmware Version: 01.01B01
User Capacity:    1,000,203,804,672 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   8
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Sat Jan 28 02:09:53 2012 GMT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (27180) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 255) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303f) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0003   225   177   021    Pre-fail  Always       -       5741
  4 Start_Stop_Count        0x0032   096   096   000    Old_age   Always       -       4284
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000e   100   253   051    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   071   071   000    Old_age   Always       -       21668
 10 Spin_Retry_Count        0x0012   100   100   051    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0012   100   100   051    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   098   098   000    Old_age   Always       -       2525
192 Power-Off_Retract_Count 0x0032   197   197   000    Old_age   Always       -       2754
193 Load_Cycle_Count        0x0032   199   199   000    Old_age   Always       -       5051
194 Temperature_Celsius     0x0022   107   098   000    Old_age   Always       -       45
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0012   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   051    Old_age   Offline      -       0
SMART Error Log Version: 1
ATA Error Count: 152 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        SC = Sector Count Register [HEX]
        SN = Sector Number Register [HEX]
        CL = Cylinder Low Register [HEX]
        CH = Cylinder High Register [HEX]
        DH = Device/Head Register [HEX]
        DC = Device Command Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 152 occurred at disk power-on lifetime: 10205 hours (425 days + 5 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  04 51 08 67 08 64 e0  Error: ABRT 8 sectors at LBA = 0x00640867 = 6555751
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 00 08 67 08 64 00 00      00:05:20.249  READ DMA EXT
  25 00 08 67 08 64 00 00      00:05:19.250  READ DMA EXT
  25 00 08 67 08 64 00 00      00:05:18.251  READ DMA EXT
  25 00 08 67 08 64 00 00      00:05:17.252  READ DMA EXT
  25 00 08 67 08 64 00 00      00:05:16.253  READ DMA EXT
Error 151 occurred at disk power-on lifetime: 10205 hours (425 days + 5 hours)
  25 00 08 67 08 64 00 00      00:05:15.254  READ DMA EXT
Error 150 occurred at disk power-on lifetime: 10205 hours (425 days + 5 hours)
  25 00 08 67 08 64 00 00      00:05:14.255  READ DMA EXT
Error 149 occurred at disk power-on lifetime: 10205 hours (425 days + 5 hours)
  25 00 08 67 08 64 00 00      00:05:13.256  READ DMA EXT
Error 148 occurred at disk power-on lifetime: 10205 hours (425 days + 5 hours)
  25 00 08 67 08 64 00 00      00:05:12.257  READ DMA EXT
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA
# 1  Short captive       Completed without error       00%       648         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Kubbur.Digital
kubbur
Póstar: 1399
Re: er diskurinn að fara að deyja ?
Pósturaf kubbur » Sun 29. Jan 2012 14:42
nobody ?
Kubbur.Digital
