Sælir.
Ég er að setja upp nýtt móðurborð. Úr Intel i AMD.
Hafa menn gert "Refresh Windows"
When you Refresh Windows, all apps that do not come with the standard Windows 1o installation, including installed programs, OEM drivers & pre-installed software, will be removed. You may also lose your digital licenses and other digital entitlements. You will have to install your apps and reactivate Windows again.
If your Windows 10 computer is facing a lot of issues including corrupt files, then it’s best to use Windows 10 Refresh Tool. The process does the following:
Keeps your personal files and settings
Replaces all Windows 11/10 system files with a new copy.
Keeps the apps that came with your PC
Keep the apps you installed from the Microsoft Store.
It ultimately fixes your computer without you worrying about any data loss.
Use it in case you are facing a lot of issues and corruption of system files. To use it, you need to download the Refresh Windows Tool from Microsoft.
Skipta um móðurborð og gera refresh windows 10, ekki reinstall?
Aimar
Höfundur - /dev/null
- Póstar: 1462
- Staðsetning: 201
GPU: AMD Radeon™ RX 9070 XT - ASrock x870e Nova - AMD 9800x3d - Corsair Rm750x - Corsair i150 - iCUE 465X RGB Mid-Tower- DDR 6000 32gb - Samsung 970 EVO 1TB M.2 2280 SSD - Win 11 Pro 64bit - ASUS ROG Swift Curved PG348Q @ 100mhz
Dr3dinn
- Tölvutryllir
- Póstar: 643
- Skráði sig: Mán 13. Ágú 2007 21:44
Re: Skipta um móðurborð og gera refresh windows 10, ekki reinstall?
Hef notað refresh oftar en einu sinni, þetta svínvirkar. Sum settnings klilkkuðu en það var takmarkað. (eldri hugb)
Vélar
https://www.howtogeek.com/444351/how-to ... re-change/
hefur virkað fyrir mig. notað á Win 10 allavega 4 x á mismunandi vélum. Bæði laptop og desk
Aimar
- Póstar: 1462
- Staðsetning: 201
brain skrifaði:https://www.howtogeek.com/444351/how-to-reactivate-windows-10-after-a-hardware-change/
takk fyrir þetta. Ég er að leitast eftir að geta notað uppsett windows áfram. Leiðindin við að setja upp alla leiki, forrit og annað er smá að kvelja mig.
