búna fixa þetta
Ice master
Höfundur - Vélbúnaðarníðingur
- Póstar: 343
- Skráði sig: Mán 10. Jan 2005 22:34
- Staðsetning: none
búna fixa þetta
np ég vill þakka mysing
Síðast breytt af Ice master á Fös 21. Jan 2005 00:25, breytt samtals 2 sinnum.
ég er bannaður...takk GuðjónR
SolidFeather
- Póstar: 2753
Ice master
- Póstar: 343
- Staðsetning: none
Revenant
- </Snillingur>
- Póstar: 1050
- Skráði sig: Fim 24. Jún 2004 12:36
- Staða: Tengdur
http://www.tweakxp.com/tweak841.aspx
Well windows seem to have a REALLY big problem when it comes to reading AVI files. It seems that when you click on an AVI file in explorer, it'll try to read the entire AVI file to determine the width,height, etc. of the AVI file (this is displayed in the Properties window). Now the problem with Windows is that if you have a broken/not fully downloaded AVI file that doesnt contain this info, Windows will scan the entire AVI file trying to figure out all these properties which in the process will probably cause 100% CPU usage and heavy memory usage.
To solve this problem all you have to do is the following:
1. Open up regedit
2. Goto HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex\PropertyHandler
3. Delete the "Default" value which should be "{87D62D94-71B3-4b9a-9489-5FE6850DC73E}"
Voila! Please not that this will no longer provide you with the windows properties displaying the AVI file information such as width, height, bitrate etc. But its a small price to pay for saving you resources.
NOTE: Please use caution when using regedit. Improper usage may cause windows to behave imcorrectly. Also, I cannot be held resposible. Backup your registry first.
1. Open up regedit
Ice master
- Póstar: 343
- Staðsetning: none
Ice master
- Póstar: 343
- Staðsetning: none
Ice master
- Póstar: 343
- Staðsetning: none
Ice master
- Póstar: 343
- Staðsetning: none
Ice master
- Póstar: 343
- Staðsetning: none
Nennti ekki að lesa þennan þráð í gegn(þar sem að póstarnir virðast misgáfluegir), en ef að þetta er AVI Preview/Delete problem, þá er einfaldast að búa til drasl-skrá(t.d. vista tómt notepad). Velja svo bæði AVI og TXT skránna, þá ætti ekki að koma preview gluggi, og þá er hægt að henda báðum skránum út
Ice master
- Póstar: 343
- Staðsetning: none
þetta er bara oceans 12 XVID ég get spilað hana með vlc en það tekur 2 min á fá vlc up og svo verð alt eins og á 100 mhz tölvu very slow
Síðast breytt af Ice master á Fim 20. Jan 2005 22:25, breytt samtals 1 sinni.
Ice master
- Póstar: 343
- Staðsetning: none
hey mysingur hvað var þetta ég prufadi það hvað á eginlega að gerast
jo það er ekki hægt að færa þessa mynd eða neitt ég prufaði að henda allla möppuna sem þetta var i en það kemur samt this bla bla bla is being used by another program or person
Síðast breytt af Ice master á Fim 20. Jan 2005 22:28, breytt samtals 1 sinni.
Ice master
- Póstar: 343
- Staðsetning: none
thx marh þú ert smarter en bill gates know what im sayin
