Að láta Windows XP vera fljótari að slökkva á sér!
viddi
Póstar: 1311
Staðsetning: <?php
Pósturaf viddi » Fös 14. Maí 2004 12:25
For years there have been advises about fast shutdown procedures involving desktop shortcuts.
No one seems to realise that in XP and ME with APM properly enabled only one press on the power button suffices to shutdown Windows in the same fashion as going through the Start > Shutdown procedure.
Like previous versions of windows, it takes long time to restart or shutdown windows xp when the "Exit Windows" sound is enabled. to solve this problem you must disable this useless sound.
click start button then go to settings -> control panel -> Sound,Speech and Audio devices -> Sounds and Audio Devices -> Sounds, then under program events and windows menu click on "Exit Windows" sub-menu and highlight it.now from sounds you can select,choose "none" and then click apply and ok.
now you can see some improvements when shutting down your system.
Start Regedit.
Navigate to HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Control.
Click on the "Control" Folder.
Select "WaitToKillServiceTimeout"
Right click on it and select Modify.
Set it a value lower than 2000 (Mine is set to 200).
KinD^
Póstar: 278
Skráði sig: Þri 04. Nóv 2003 02:01
Staðsetning: VKóp
Pósturaf KinD^ » Fös 14. Maí 2004 15:10
næs
mehehehehehe ?
Sveinn
Póstar: 728
Skráði sig: Sun 07. Sep 2003 20:04
Staðsetning: Rvk
Pósturaf Sveinn » Sun 16. Maí 2004 19:23
sá þetta einhvernstaðar á íslensku :lol:
