hvernig skal breyta bókstaf á hörðum disk?
biggi1
Póstar: 440
Skráði sig: Mið 01. Des 2004 00:33
Staðsetning: Brh..
Pósturaf biggi1 » Sun 17. Des 2006 00:10
ég veit ekki hvernig það atvikaðist, en af einhverjum ástæðum heitir local disk ekki C.. það er geimsludiskurinn sem fékk C bókstafinn, báðir stútfullir af efni, hvernig get ég svissað bókstöfunum?
CendenZ
Póstar: 2919
Staðsetning: Á þessu spjalli
Pósturaf CendenZ » Sun 17. Des 2006 02:24
biggi1
Póstar: 440
Staðsetning: Brh..
Pósturaf biggi1 » Sun 17. Des 2006 16:20
skeit uppá bak :lol:
nei heirðu.. það er ekki rétt :) ég get ekki breitt þessu útaf því að það er ekki hægt að breita úr C .. drasl
beatmaster
Póstar: 3100
Pósturaf beatmaster » Sun 17. Des 2006 17:50
ÖrMjúkur skrifaði:This article describes how to change the system or boot drive letter in Windows. For the most part, this is not recommended, especially if the drive letter is the same as when Windows was installed. The only time that you may want to do this is when the drive letters get changed without any user intervention. This may happen when you break a mirror volume or there is a drive configuration change. This should be a rare occurrence and you should change the drive letters back to match the initial installation.
To change or swap drive letters on volumes that cannot otherwise be changed using the Disk Management snap-in, use the following steps.
Note In these steps, drive D refers to the (wrong) drive letter assigned to a volume, and drive C refers to the (new) drive letter you want to change to, or to assign to the volume.
This procedure swaps drive letters for drives C and D. If you do not need to swap drive letters, simply name the \DosDevice\letter: value to any new drive letter not in use.
Back to the top Back to the top
Change the System/Boot Drive Letter
Warning Serious problems might occur if you modify the registry incorrectly by using Registry Editor or by using another method. These problems might require that you reinstall your operating system. Microsoft cannot guarantee that these problems can be solved. Modify the registry at your own risk.
1. Make a full system backup of the computer and system state.
2. Log on as an Administrator.
3. Start Regedt32.exe.
4. Go to the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
5. Click MountedDevices.
6. On the Security menu, click Permissions.
7. Verify that Administrators have full control. Change this back when you are finished with these steps.
8. Quit Regedt32.exe, and then start Regedit.exe.
9. Locate the following registry key:
10. Find the drive letter you want to change to (new). Look for "\DosDevices\C:".
11. Right-click \DosDevices\C:, and then click Rename.
Note You must use Regedit instead of Regedt32 to rename this registry key.
12. Rename it to an unused drive letter "\DosDevices\Z:".
This frees up drive letter C.
13. Find the drive letter you want changed. Look for "\DosDevices\D:".
14. Right-click \DosDevices\D:, and then click Rename.
15. Rename it to the appropriate (new) drive letter "\DosDevices\C:".
16. Click the value for \DosDevices\Z:, click Rename, and then name it back to "\DosDevices\D:".
17. Quit Regedit, and then start Regedt32.
18. Change the permissions back to the previous setting for Administrators (this should probably be Read Only).
19. Restart the computer.
