Er með til sölu flottan hvítan LG 32QK500-W 31.5" 16:9 FreeSync IPS Gaming Monitor.
Key Features
In-Plane Switching (IPS) Panel
HDMI | DP | Mini DisplayPort Inputs
2560 x 1440 QHD Resolution
1000:1 Static Contrast Ratio
300 cd/m² Brightness
178°/178° Viewing Angles
8 ms Response Time (GtG)
1.07 Billion Colors
The 32QK500-W 31.5" 16:9 FreeSync IPS Gaming Monitor from LG is built with an In-Plane Switching panel that provides you with vivid colors and wide 178° viewing angles. For gamers, it also features a 75 Hz refresh rate with AMD FreeSync support. Specs-wise, it has a 2560 x 1440 QHD resolution, a 1000:1 static contrast ratio, a 300 cd/m² brightness rating, and support for up to 1.07 billion colors. Once it's connected, you can tilt it to best fit your viewing preference or install an optional VESA stand, mount, or arm if needed.
AMD FreeSync
AMD FreeSync technology syncs your display's refresh rate and graphics card's frame rate output to reduce screen tearing, stuttering, and ghosting for a smoother gaming experience.
Gaming Features
This monitor features multiple gaming add-ons to up your game: Dynamic Action Sync reduces input lag, Black Stabilizer improves visibility in dark scenes, and an onscreen Crosshair enhances accuracy.
Reader Mode
Reader mode reduces blue light emissions to help reduce eyestrain and fatigue over extended viewing sessions.
On-Screen Control
Easily adjust your monitor settings in an onscreen window instead of fiddling with buttons. Access volume, brightness, picture mode presets, Screen Split 2.0, and Dual controller with just a few clicks.
Verð 35.000kr
[TS] LG 31,5" IPS Free Sync 1440p skjár.
Höfundur - Besserwisser
- Póstar: 3843
- Skráði sig: Sun 16. Mar 2003 13:22
Re: [TS] LG 31,5" IPS Free Sync 1440p skjár.
Opinn fyrir tilboðuðm.
Síðast „Bumpað“ af Tiger á Sun 11. Des 2022 10:36.
