Rúmlega 2 ára gamalt.
Sambærilegt kort kostar nýtt 60K-ish, fljótt á litið.
Sambærileg notuð kort með kosta 40K-ish með VSK á eBay.
https://www.gigabyte.com/Graphics-Card/ ... XOC-8GD#kf
Graphics Processing
GeForce® GTX 1070
Core Clock
Boost: 1746 MHz / Base: 1556 MHz in OC mode
Boost: 1721 MHz / Base: 1531 MHz in Gaming mode
CUDA® Cores
1920
Process Technology
16 nm
Memory Clock
8008 MHz
Memory Size
8 GB
Memory Type
GDDR5
Memory Bus
256 bit
Card Bus
PCI-E 3.0 x 16
Digital max resolution
7680x4320
Multi-view
4
Card size
H=37 L=169 W=131 mm
PCB Form
ATX
DirectX
12
OpenGL
4.5
Recommended PSU
500W
Power Connectors
8 pin*1
Output
Dual-link DVI-D *2
HDMI-2.0b*1 (Max Resolution: 4096x2160 @60 Hz)
Display Port-1.4 *1
SLI Support
2-way SLI HB
