Til sölu öflugur aflgjafi, Corsair AX1200, 1200W
Unique Design, Exclusive to Corsair
The Professional Series Gold AX1200 has been designed from the ground-up by Corsair’s power engineering team, and is therefore unique and exclusive to Corsair.
100.4 Amp Single +12V Rail
The AX1200’s massive 100.4 Amp (1204.8 Watt) single +12V rail makes it the ideal power supply for ultra-high end NVIDIA SLI™ and ATI CrossFireX™ gaming PCs based around multi-core CPUs.
80 Plus® Gold Efficiency
The sophisticated electrical design, incorporating advanced magnetic modeling during development in order to optimize magnetic component performance, delivers exceptionally high energy efficiency (90% and above). This meets or exceeds the requirements for 80 Plus Gold certification.
Outstanding Noise/Ripple and DC Voltage Regulation
The AX1200 features individual DC-DC regulation for 3.3V, 5V and 12V rails, and secondary side synchronous rectification, utilizing MOSFETs that have lower losses than the conventional output rectification schemes. An advanced 4-layer modular connector board PCB ensures a better ground return plane, lower resistance and low voltage drops. This, combined with circuit trace optimization, also helps to minimize ripple and noise.
Fully Modular Cable System
The fully-modular, low-profile cable system provides maximum flexibility when building or upgrading your PC, and maximum airflow through your chassis. This allows you to utilize only the cables that you need, reducing cable clutter and maximizing the cooling performance of your PC.
Zero Voltage Switching / Zero Current Switching Technology
The Corsair AX1200 utilizes ZVS / ZCS technology to switch at near 0V and 0A, which ensures there are minimal switching losses, thereby maximizing efficiency and further reducing waste heat.
Ultra Low Noise Design
The AX1200 utilizes a low-noise, thermally-controlled 140mm fan, and employs sophisticated techniques to enhance cooling performance and reduce noise. This includes a specially designed PCB that channels airflow to reduce back-pressure and maximize the fan’s cooling ability.
https://www.kitguru.net/components/powe ... -review/5/
Verðhugmynd: 10.000
Selst hæstbjóðanda
áhugasamir hafi samband!
Til sölu Corsair AX1200 aflgjafi *SELDUR*
Höfundur - Stjórnandi
- Póstar: 1312
- Staðsetning: MHz=MHz+1
- Staða: Tengdur
AMD Ryzen 3900XT * Nvidia GTX 4080s * Asus TUF mATX * 64GB DDR4
Jensbo D31* Corsair PSU1000w * Alienware 34" OLED AW3423DWF
- Póstar: 1312
- Staða: Tengdur
Re: Til sölu Corsair AX1200 aflgjafi
- vélbúnaðarpervert
- Póstar: 966
- Skráði sig: Þri 28. Jún 2016 11:27
- Staðsetning: Njarðvík
Hvað er hann gamall ?
| BQ! Pure Base 500DX | Ryzen9 7900x | ASRock X670e | 3070 ti - 8 gb | Samsung 980 Pro NVMe PCIe M.2 - 2tb og 2x 1 tb | 1x 16 tb og 1x 20 tb | Corsair HX1200i | G.Skill 64GB Trident Z5 DDR5 6000MHz | Samsung Odyssey G5 34" WQHD sveigður | JBL Quantum Duo | HyperX leikjastóll |
- Póstar: 1312
- Staða: Tengdur
emil40 skrifaði:Hvað er hann gamall ?
gleymdi að taka það fram
en hann er ca 6 ára, corsair býður 7 ára ábyrgð á þessum aflgjafa, þetta er hágæða aflgjafi sem á að endast 10-15 ár
kemur með öllum snúrum, nýbúinn að rykhreinsa hann líka
- Póstar: 1312
- Staða: Tengdur
- Póstar: 1312
- Staða: Tengdur
*lækkað verð*
