Er með tvær ónotaðar IP myndavélar, keypti þrjár en þurfti svo bara að nota eina.
Vstarcam C7824WIP
720P HD - H.264
Bæði Wifi eða víraðar
Night mode í myrkri, virkar vel.
PAN/Tilt 360 gráður með PTZ stuðning
Hægt að tengja við síma app
Vegg/loft festing fylgir með
2-Way hljóð
Hægt að hooka þessu upp á móti VLC með t.d RTSP straumi.
Features :
12pcs LED, IR distance 10M.
Lens 3.6 mm wireless security camera support memory card.
Support ONVIF 2.0, RTSP protocol.
WPS one key setup WiFi, acoustic wave wifi setting.
720P, VGA, QVGA triple stream.
Two-way audio, remote Pan/Tilt rotate.
Wi-Fi/802.11/b/g/n, support dynamic IP.
Motion detection: Send email alert, FTP upload, record video into sd card when alarm triggered.
iPhone, 3G phone, IOS and Android Smartphone supported (don't support windows APP)
Multi-language, Firefox, Safari, Google browser.
Pan: 270 degree, Tilt: 80degree, auto cruise.
Support 64GB TF Card.
Specification :
System OS :Embedded Linux OS
System security :Three level user authority management
Online users :Support 4 online visitors simultaneously
DDNS :Free DDNS
Control protocol :ONVIF 2.4 protocol, high interoperability
Processor : Hisilicon processor.
Built-in ARM926 @Max. 440MHz and a high-speed video co-processor.
Reset:Long press for 15 seconds to restore back to factory settings
Collection :Image sensor 1/4inch 720p Progressive scan CMOS sensor
CMOS:Support AWB, AGC, BLC
Imaging area :4.40mm x 2.52mm
SNR:=41dB
Minimum illumination :0.8Lux/F1.4 (colourful model ),0.3Lux/F1. (B&W mode)
Lens/viewing angle:3.6mm@F1.4/56.14°
Night vision:Dual IR-CUT filter auto switch, 12pcs 850nmF5mm LED,10m IR distance
IR control:IR turned on: night vision view enabled, infrared Ray, ICR auto detect.
IR turned off: night vision disabled, infrared ray off, ICR stay in day view mode.
Video:Compression Format H.264 Main Profile/H.264 Baseline Profile/MJPEG/JPEG Baseline
Video coding process Multi-stream: 720P/24fps+VGA/30fps+QVGA/30fps+720P @1fsJPEG snapshot
Resolution 720p / VGA / QVGA
Bit Rate CBR / VBR, output bit rate range: 128-4096kbps
Max.Frame rate 25fps
Picture Adjustment Contrast, brightness, saturation, chroma are adjustable.
Audio Input Built in -48dB Microphone
Output Built in speaker(8O1W)
Sampling frequency / width 8KHz/16bit
Compression format ADPCM/32kbps
Network Interface 10Base-T / 100Base-TX, RJ45 connector
Network Protocol TCP/IP, HTTP, TCP, UDP, SMTP, FTP, DHCP, DNS, DDNS, NTP, UPnP, RTSP, P2P, ONVIF, etc.
WIFI WiFi802.11b/g/n
Antenna 3dBi antenna, stronger signal, more stable
Wireless network security One key setup WiFi , don't need a network cable.
Storage Storage mode Local storage / client storage
Interface Micro SD/TF, support 64G TF record.
Pan-Tilt P/T Pan: 270°, Tilt: 80°
Preset Position Support up to 15 preset positions
Limit method Software limit position, more accurate preset positions,lower Pan Tilt failure rate.
Alarm Motion detection Support motion detection
Alarm action Video upload via email/FTP server, Mobile App alarm
Physical index Rated Voltage DC5 / 2A±0.3V
Power consumption Rated power: 3.0W (IR ON)
Working environment Working Temperature: -20-70?, Working Humidity 90%
Weight Gross Weight: 330g (Note: in kind prevail)
Housing material ABS plastics
Camera size 145 x 110 x 125 mm (L x W x H)
Installation Wall mounting, ceiling mounting
Package includes :
1 x VStarcam C7824WIP IP Camera
1 x Power Adapter ( EU Plug )
1 x Camera Holder
1 x English User Manual
4 x Screw
Fara á kostnaðarverði, 6þús stykkið.
2x HD IP myndavélar
Höfundur - Kerfisstjóri
- Póstar: 1270
- Skráði sig: Þri 07. Sep 2004 18:18
- Staðsetning: Router(config)#
2x HD IP myndavélar
Síðast „Bumpað“ af ponzer á Sun 19. Maí 2019 00:07.
