Selt
GPU - Radeon R9 270X
Bus Type - PCI-E 3.0 x16
GPU Clock Base - 1030 MHz
Silent Mode - 1050 MHz
Gaming Mode - 1080 MHz
OC Mode - 1120 MHz
Memory - 2 GB GDDR5
Memory Clock Speed - 1.4 GHz
5.6 GHz effective at QDR
Memory Interface - 256-bit
RAMDAC - 400
Output - 1 x DVI-D dual-link 1 x DVI-I dual-link 1 x HDMI - HDMI 1.4a support 1 x DisplayPort - DP 1.2 support
Maximum Resolution - 2560 x 1600
CrossFire - Use two compatible GPUs in tandem - CrossFire Bridge Interconnect required
Dimensions - (26.3 x 12.6 x 3.8 cm)
Weight - 1.7 lb (757.0 g)
[Selt] Radeon R9 270X GAMING - Skoða skipti á örgjörvakælingu
Höfundur - Vélbúnaðarníðingur
- Póstar: 380
- Skráði sig: Fim 26. Des 2002 23:38
Síðast breytt af Sultukrukka á Fim 01. Nóv 2018 21:07, breytt samtals 1 sinni.
- Póstar: 380
