[TS]Arctic Cooling Freezer 7 Pro Rev.2 mjög hljóðlát örgjörvakæling
tanketom
Póstar: 1043
Pósturaf tanketom » Lau 22. Sep 2018 17:34
Its low noise impeller and patented fan holder ensures the fan to work quietly even under full load.
The test done by Tom's Hardware has shown that the Freezer 7 PRO is 3-15 dBA quieter compared to the Cooler Master Hyper 212 Plus, Tuniq Tower 120 Extreme and Thermaltake Frio at full load.
Thanks to the PWM control, the fan speed adjusts according to the CPU temperature and thus the noise level remains at an absolute minimum which qualifies it as a silent cooler. Click here to see how the PWM control settings can be changed according to your performance and noise preference.
• Fyrir Intel sökkla: 1150, 1151, 1155, 1156, 775 & 1366
• Fyrir AMD sökkla: 754, 939, AM2, AM2+, AM3, AM3+, FM1 & FM2
• Hljóðmyndun: 0.5 Sone @ 2,200 RPM
• Hraði: 900 - 2200 RPM
• Ummál: 96 x 108 x 127 mm ( L x W x H )
• Tengi: 4-pinna PWM
• Þyngd: 520gr
VERÐ: 3500 kr
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do
