Ertu orðin þreytt á því að þurfa að endurræsa routerinn reglulega til að fá netið í gang?
Alvöru ljósleiðararouter frá Cisco til sölu.
15þ. eða besta boð.
http://www.linksys.com/us/p/P-EA4500/
Device Type Wireless router - 4-port switch (integrated)
Frequency Band 2.4 GHz / 5 GHz
Authentication Method RADIUS, Radio Service Set ID (SSID)
Status Indicators Port status, power, USB, Internet, Port status, power
Encryption Algorithm WPA, WPA2, WEP, 128-bit WEP, WPA, WPA2
Routing Protocol RIP, static IP routing
ManufacturerCisco
MODEM
Antenna Qty 6
NETWORKING
Form Factor desktop
Type wireless router
Connectivity Technology wired, wireless
Data Link Protocol Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Network / Transport Protocol DHCP, L2TP, PPPoE, PPTP
Features 128-bit encryption, DMZ port, DHCP server, IPv6 support, parental control, dynamic DNS server, port forwarding, firmware upgradable, port triggering, reset button, wall mountable, MAC address filtering, NAT support, Quality of Service (QoS), Stateful Packet Inspection (SPI), VPN passthrough, Wi-Fi Protected Setup (WPS), UPnP Media Server, firewall protection
Compliant Standards DLNA CERTIFIED, IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, Wi-Fi CERTIFIED
Wireless Protocol 802.11a/b/g/n
Remote Management Protocol HTTP, HTTPS
Data Transfer Rate 900 Mbps
WAN Ports Qty 1
Integrated Switch 4-port switch
Key Features USB port, VPN support, firewall
POWER DEVICE
Type external power adapter
Form Factor External
INTERFACE PROVIDED
Interface Ethernet 10Base-T/100Base-TX/1000Base-T
Qty 1, 4
Connector Type 4 pin USB Type A, RJ-45
Type LAN, USB 2.0, USB, WAN
ANTENNA
Antenna Internal
Antenna Qty 6
Antenna Form Factor internal
MISCELLANEOUS
Encryption Algorithm 128-bit WEP, WEP, WPA, WPA2
Microsoft Certifications Compatible with Windows 7
Color Category black
SYSTEM REQUIREMENTS
OS Required Apple MacOS X 10.4.11, Windows 8.1 (32/64 bits), Apple OS X 10.8 Mountain Lion, Microsoft Windows 7 (32/64 bits), Microsoft Windows Vista (32/64 bits) SP1 or later, Microsoft Windows XP SP3, Windows 8 (32/64 bits)
Til sölu Cisco Linksys EA4500 router (ljósleiðara)
Höfundur - Internetsérfræðingur
- Póstar: 6773
- 30422499-CB83-40B4-B72C-72057615029F.jpeg (36.73 KiB) Skoðað 558 sinnum
- Póstar: 6773
Re: Til sölu Cisco Linksys EA4500 router (ljósleiðara)
- Póstar: 6773
