Nvidia Quadro M4000
selur2
Póstar: 68
Skráði sig: Lau 15. Ágú 2009 12:22
Nvidia Quadro M4000
Pósturaf selur2 » Fim 14. Sep 2017 19:24
Góðan daginn
Langar að athuga hvort einhver vilji kaupa Nvidia Quadro M4000 skjákort.
SPECIFICATIONS
GPU Memory: 8 GB GDDR5
Memory Interface: 256-bit
Memory Bandwidth: 192 GB/s
NVIDIA CUDA® Cores: 1664
System Interface PCI Express 3.0 x16
Max Power Consumption 120 W
Thermal Solution Active
Form Factor 4.4” H × 9.5” L,
Single Slot, Full Height
Display Connectors 4x DP 1.2
Max Simultaneous Displays: 4 direct, 4 DP 1.2
Multi-Stream
Max DP 1.2 Resolution 4096 × 2160 at 60 Hz
Max VGA Resolution 2048 × 1536 at 85 Hz
Graphics APIs Shader Model 5.0,
OpenGL 4.54
DirectX 12.05
Compute APIs CUDA, Direct
Verðhugmynd: 100.000.-
nú eða tilboð.
