[TS] ASUS VG236H 23.6" 3D/120HZ leikjaskjár[Selt]
jonni82
Póstar: 12
Skráði sig: Mið 24. Ágú 2011 02:30
Staðsetning: í bílnum
Pósturaf jonni82 » Lau 18. Okt 2014 22:01
Til sölu ASUS VG236H 23.6" 3D/120HZ leikjaskjár.
Í toppstandi og sér ekkert á honum, skjárinn er umþabil 2ja ára gamall.
Alltaf notaður í 1920x1080(1080p) 120HZ 2d mode.
Ástæða sölu er að ég ætla að uppfæra mig í 27" ASUS 3D/144HZ skjá.
Video Inputs DVI-D (120 Hz 3D), HDMI, Component YPbPr
Panel Type TN (with Dual Side driving), CCFL backlight
Pixel Pitch 0.265 mm
Colors 16.7 Million (24 bit)
Brightness 400 nits maximum
Contrast Ratio 1,000:1 (standard), or 100,000:1 (dynamic)
Response Time 2ms (g2g) with Overdive/"Trace Free" control
Viewable Size 23" (54.8 cm) diagonal
Resolution 1920x1080 at 120Hz (1080P)
Viewing Angle 170 degrees horizontal, 160 degrees vertical
Power Consumption (operation) <60 watts typical
Power Consumption (standby) <2 watts typical
Screen Treatment Glossy (with antireflection coating)
Height-Adjustable Yes: ~4" (100 mm) of travel
Tilt Yes: -5 degrees to 15 degrees
Pivot No
Swivel Yes: +/- 150 degrees
VESA Wall Mounting Yes - 100x100mm
Dimensions w/ Base (WxHxD) 21.7" (550 mm) x 16.5" (420 mm) x 9.8" (250 mm)
Weight w/o Stand 15.4 lbs (7.0 kg)
Additional Features NVIDIA 3D Vision Kit, 120 Hz operation
Limited Warranty 3 years - repair or replacement
Verð: 30.000kr.-
Síðast breytt af jonni82 á Fim 27. Nóv 2014 17:41, breytt samtals 2 sinnum.
jonni82
Póstar: 12
Re: [TS] ASUS VG236H 23.6" 3D/120HZ leikjaskjár
Pósturaf jonni82 » Sun 19. Okt 2014 21:26
jonni82
Póstar: 12
Pósturaf jonni82 » Þri 21. Okt 2014 18:17
Villi ólafs
Póstar: 1
Skráði sig: Þri 21. Okt 2014 19:03
Pósturaf Villi ólafs » Þri 21. Okt 2014 19:10
sendi póst.
jonni82
Póstar: 12
Pósturaf jonni82 » Mið 22. Okt 2014 18:47
jonni82
Póstar: 12
Pósturaf jonni82 » Fim 23. Okt 2014 20:57
upp lækkað verð
jonni82
Póstar: 12
Pósturaf jonni82 » Sun 26. Okt 2014 00:24
jonni82
Póstar: 12
Pósturaf jonni82 » Þri 28. Okt 2014 23:37
