Samsung S27C450B 27 inch Full HD selt
GameOver
Póstar: 25
Skráði sig: Sun 07. Sep 2008 02:38
Pósturaf GameOver » Sun 29. Jún 2014 18:23
27" S27C450B Series 4 LED Business Monitor. árs gamal, þriggja ára ábyrgð íTölvutækni
TN, LED Type
27" (16:9) Screen Size
597.6mm (H) x 336.15mm (V) Active Display Size (H x V)
300cd/m² Brightness
Mega ∞ DCR (Static 1000:1) Contrast Ratio
1920 x 1080 Resolution
0.31125mm (H) x 0.31125mm (V) Pixel Pitch
5ms (On / Off) Response Time
170° / 160° Viewing Angle (Horisontal / Vertical)
16.7M Colour Support
1 x D-Sub
1 x DVI
MAX : 639 x 527.8 x 224mm
MIN : 639 X 397.8 x 224mm
Set Dimension with Stand (W x H x D)
639 x 378.1 x 56.7mm Set Dimension without Stand (W x H x D)
722 x 187 x 461 Package Dimension (W x H x D)
6.2kg Set Weight with Stand
4.55kg Set Weight without Stand
8kg Package Weight
100 - 240V (50 / 60hz) Power Supply
30W (Typ.) Power Consumption
22W Power Consumption (Stand-by)
Internal Power Type
http://www.samsung.com/uk/business/business-products/business-monitor/performance/LS27C45KBS/EN
Síðast breytt af GameOver á Fös 01. Ágú 2014 21:44, breytt samtals 2 sinnum.
tanketom
Póstar: 1052
Re: Samsung S27C450B 27 inch Full HD Til Sölu
Pósturaf tanketom » Sun 29. Jún 2014 19:12
EF ÞAÐ ER EITTHVAÐ SEM ÉG HATA MEST Í HEIMI ÞÁ ER ÞAÐ ÞEGAR FÓLK KEMUR EKKI MEÐ VERÐ TIL VIÐMIÐUNAR EÐA ALLAVEGANA HVAÐ HANN KOSTAÐI NÝR! :mad :mad :mad :mad
Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do
Alfa
Póstar: 842
Staðsetning: Vestmannaeyjar
Pósturaf Alfa » Mán 30. Jún 2014 20:27
Verð: 40þ
MISSTU EKKI LEGVATNIÐ !
trausti164
Póstar: 854
Pósturaf trausti164 » Mán 30. Jún 2014 20:37
Alfa skrifaði:
Verð: 40þ
Auglýsingunni var breytt 1 sinni örfáum mínútum eftir að Tanketom commentaði, ég ætla að giska á að þetta verð hafi verið sett inn þá.
Spookz
Póstar: 172
Skráði sig: Fim 10. Feb 2011 16:03
Pósturaf Spookz » Þri 01. Júl 2014 08:01
Býð 35
GameOver
Póstar: 25
Pósturaf GameOver » Sun 06. Júl 2014 16:27
TTT
GameOver
Póstar: 25
Pósturaf GameOver » Þri 15. Júl 2014 18:03
TTT
