UniFi Network Video Recorder NVR 2TB (UVC-NVR-2TB) og 16stk Myndavélar - G3 Dome og G3 Micro - Selst saman eða í pörtum
Stulloz
Póstar: 141
Skráði sig: Fim 26. Jan 2012 19:19
Pósturaf Stulloz » Fim 18. Des 2025 16:23
Selst saman eða í stykkjatali ef menn vilja fá sér eina tvær vélar, eða bæta við þegar uppsett Unifi Kerfi hjá sér.
UVC-G3-DOME
The UniFi Video Camera G3 Dome features a wide-angle lens and 1080p video performance for expanded surveillance coverage. Mounting options include wall or ceiling installations. The infrared LEDs and an automatic IR cut filter provide day and night monitoring.
• 1080p Full HD, 30 FPS, H.264
• EFL 2.8 mm, ƒ/2.0
• Wide-Angle Lens
• 802.3af PoE or 24V Passive PoE
• Built-in Microphone
• Wall or Ceiling Mount
UVC-G3-MICRO
The UniFi Video Camera G3 Micro features a wide angle lens and 1080p video resolution. Multiple mounting options allow the camera to be installed almost anywhere indoors for permanent or temporary surveillance. The infrared LEDs and mechanical IR cut filter enable uninterrupted surveillance. The built-in microphone and speaker enable two-way audio communication.
Hægt að keyra PoE eða með AC Adapter (er með bæði)
• EFL 2.7 mm, ƒ/2.2
• 802.11 a/b/g/n, 2.4 GHz/5 GHz Dual-Band Wi-Fi
• 802.3af PoE
• Mic and Speaker for Two-Way Audio
• Permanent Mount: Wall or Ceiling
• Temporary Mount: Magnetic or Table Stand
The Ubiquiti UniFi UVC-NVR-2TB is a plug-and-play network video recorder designed for seamless integration with the Ubiquiti UniFi Video Camera range. The UVC-NVR-2TB has a 2TB built-in hard drive, which provides approximately 4800 hours at 480p, 1600 hours at 720p or 700 hours at 1080p.
UniFi UVC-NVR-2TB Key Features
Built-in 2TB HDD (hægt að tengja external USB diska við - græjan er með 6x USB tengjum, (2xUSB 3.0 og 4x USB 2.0))
User-Definable Disk Space: Allows the user to keep a set amount of free disk space
Date-Based Auto Purge: Automatically deletes recordings after a certain number of days
Easy Access via a Web browser
Multi-Site Support
Intuitive Management Software
The Ubiquiti UniFi UVC-NVR-2TB comes pre-installed with the intuitive controller UniFi Video Software. The UVC-NVR-2TB also records footage using the H.264 format instead of M-JPEG, resulting in sharper videos with smaller file sizes.
Scalability
The UniFi NVR 2TB readily manages and records video from up to 20 cameras
Plug and Play Installation
The UniFi NVR 2TB features a setup wizard for easy configuration. Its pre-installed UniFi Video software automatically detects cameras for rapid deployment.
The advanced software on the UniFi NVR 2TB features an advanced UI and extensive feature set, including custom motion detection zones, event recordings, email alerts, live view monitoring, disk management and analytics
Ubiquiti UniFi UVC-NVR-2TB - Technical Specifications
General:
Dimensions: 135 x 190 x 25 mm (5.31 x 7.48 x 0.98")
Weight: 483 g (17 oz)
Processor: Intel J1800
Memory: 4 GB
Hard Drive Capacity: 2 TB
Networking Interface: (1) 10/100/1000 Ethernet Port
Power Supply: 65W, 19V, 3.42A
Certifications: FCC, CE, IC
Interfaces: Web Browser, iOS and Android
System Setup:
- Plug-and-Play Installation,
- Automatic Camera Detection
Camera Support: Recommended for up to 20 UniFi Video Cameras
Supported Browsers: Chrome
Supported Smartphones: iPhone and Android
Media Format: MP4 (H.264/AAC)
Scheduling:
- Day/Time/Camera
- Scheduled Video Recording/Motion
- Detection/Email Alerts
Views: Multiple Camera Live Grid View, Recorded Video Playback, Full Screen, Windowed
Software: Browser-Based Interface, Tablets, and Smartphones Supported
System Setup:
NVR Camera Support: Recommended for up to 20 UniFi Video Cameras
Supported Devices:
- Operating Systems: Windows, Apple, and Linux
- Browsers: Chrome, Internet Explorer 10 (or above), Firefox, and Safari
- Smartphones: iPhone and Android
Scheduling:
- Day/Time/Camera
Síðast breytt af Stulloz á Fim 18. Des 2025 16:27, breytt samtals 1 sinni.
Stulloz
Póstar: 141
Re: UniFi Network Video Recorder NVR 2TB (UVC-NVR-2TB) og 16stk Myndavélar - G3 Dome og G3 Micro - Selst saman eða í pör
Pósturaf Stulloz » Fös 19. Des 2025 20:27
Tvær UVC-G3-MICRO vélar farnar - 6 eftir
