Vatns kæling ?
assi
Póstar: 17
Skráði sig: Lau 27. Des 2003 07:49
Vatns kæling ?
Pósturaf assi » Þri 20. Jan 2004 18:00
Er þetta ekki shitið :)
FEATURES
New and improved DC water pump outlast the life expectancy of traditional open water motor.
Designed & improved by various respectable manufacturers and engineers to maximize water-flow, water capacity, thermal resistance.
Pure copper design provides maximum heat transfer rate. Specially processed to prevent copper oxidation.
DC water pump's low power consumption eliminate the need for external power source or additional power supply unit.
System is highly upgradeable. Will work with future CPUs through simple upgrade
Chassis Requirement
(If you are not using Xaser II Series chassis, please check the space of your chassis in advance)
Chassis Dim.: H20.6xW8.1xD18.6
Copper Radiator clearance requirement: H3.6Xw5.7xD4.0from the base to Driver bay
Water Pump clearance requirement: H4.7xW5.3xD2.0 inside the chassis
Water Block
Dim: 70x50x12 mm
Material: Copper Forging/ Nickel Plating
Weight: 266g
Features
Made by pure copper and with high conductivity
3D water channel enhance the heat conduction and convection
Radiate water block spread the heat from the center
Intelligent Water Tube
Better water-flow and avoid compression
The spring represents the best solution to ensure maximum water-flow
Made by silicone tube
Copper Radiator
Dim: 86x130x89 mm
Material: Copper Pipe with Staged Copper Fin
Fan Dim: 80x80x25 mm
Fan Rated Voltage: 12V
Fan Rated Current: 0.14A
Fan Power Input: 1.68W
Fan Speed: 2400 ? 10% RPM
Max. Air Flow: 38.4 CFM
Noise: 22 dBA
Life Expectancy: 50000 hr.
Connector: 3 Pin
Weight: 410g
Features
High density copper fins to maximize the surface area and with high conductivity
The innovative low speed fan can reduce the system noise and maximize the heat exchange efficiently
DC 12V Water Pump
Dim: 100x50x86 mm
Rated Voltage: 12V
Rated Current: 0.16A
Power Input: 2W
Water Pressure: 1.2 kg/cm2
Pump Speed: 90 L/hr
Connector: 3 Pin
Noise: 20 dBA
Bearing Type: Ceramics Bearing
Weight: 230g
Features
Small size, low noise, low current and high pump speed
Blue LED light will be a security to warn you if the pump is functioning and also show you the water level
Secured by L type clip to minimize the vibration and noise from motor
The motor will automatically adjust its speed from 1800rpm to 2500rpm based on the water resistance
Monitor the motor speed through the 3 Pin connector
Back-up Receiver
Back-up Receiver stores additional water to ensure that system is full at all time
Features
Install with Back-up receiver
With the see-through Back-up Receiver, you can check the water at any time
When the water level within the system is decreasing, Back-up Receiver
will automatically supply the necessary liquid to DC Water Pump
Install without Back-up receiver
Back-up Receiver is not required for Aquarius II to operate. Users may not wish to have additional accessories outside of the case
Users will need to check the water level within the DC Water Pump monthly. Refill the system if necessary
To refill the DC Water Pump, please remove the Tube from top part of the DC Water Pump. Then connect the Tube from the Back-up Receiver to it to refill
Fann þetta á útlenski síðu kostar eitthvað 10.000
gnarr
Póstar: 6591
Pósturaf gnarr » Þri 20. Jan 2004 18:04
þetta er gorr ef þú vilt losna við viftur. en þú overclockar ekki mikið með þessu.
Cras Override
Póstar: 379
Skráði sig: Sun 28. Des 2003 01:01
Staðsetning: tölvuheiminum
Pósturaf Cras Override » Þri 20. Jan 2004 18:05
bara fínt held ég ef að maður ætlar ekki mikið í það að overclocka.
MESS WITH THE BEST DIE LIKE THE REST
odinnn
Póstar: 473
Skráði sig: Fim 26. Sep 2002 20:37
Staðsetning: Hef ekki glóru!
Pósturaf odinnn » Þri 20. Jan 2004 20:21
endilega komdu með link
Desktop: i5 4670K|Asus Maximus VI Impact|EVGA GTX780SC|Adata XPG PC3-17000 16Gb
Server: C2D6600|Asus P5B deluxe Wi/Fi|GeiL PC6400 6Gb
Damien
Póstar: 389
Skráði sig: Lau 31. Maí 2003 23:07
Staðsetning: Ak-X
Pósturaf Damien » Þri 20. Jan 2004 22:06
hmm 90 l/h er ekki mikið...
Eins og áður hefur komið framm er ég t.d. með 1200 eða 1400 l/h (man ekki :oops: )
Damien
Guffi
Póstar: 178
Skráði sig: Lau 29. Nóv 2003 16:44
Staðsetning: Kópavogur
Pósturaf Guffi » Þri 20. Jan 2004 22:58
ég væri til í að splæsa á eina sona
