pata yfir í sata breyti
Halldór
Póstar: 331
Skráði sig: Lau 30. Apr 2011 22:27
Pósturaf Halldór » Þri 07. Feb 2012 12:28
Mér fanntar pata yfir í sata breyti. Hvar get ég nálgast þannig? (Þarf að formata pata HDD)
i7 2600k | Corsair H80 með 2x Gentle Typhoon AP-15 1850RPM | Gigabyte Z68X-UD7-B3 | G.Skill sniper 2x4GB @ 1600 MHz | Sapphire Radeon 6950 Flex edition | Corsair 750D | SSD: OCZ Vertex 3 MAX IOPS 120 GB| 1TB Seagate Barracuda | Corsair AX1200 | W7 x64
Benzmann
Póstar: 1590
Staðsetning: Breiðholt
Re: pata yfir í sata breyti
Pósturaf Benzmann » Þri 07. Feb 2012 13:14
hvenær byrjuðu IDE diskar að kallast PATA ?
Póstar: 6844
Pósturaf Viktor » Þri 07. Feb 2012 13:17
benzmann skrifaði:hvenær byrjuðu IDE diskar að kallast PATA ?
IDE var í raun bara nafnið sem WD gaf þessu, svo var farið með þetta lengra og Pararell ATA varð að samheiti :)
Parallel ATA (PATA), originally AT Attachment, is an interface standard for the connection of storage devices such as hard disks, solid-state drives, floppy drives, and optical disc drives in computers. The standard is maintained by X3/INCITS committee.[1] It uses the underlying AT Attachment (ATA) and AT Attachment Packet Interface (ATAPI) standards.
The Parallel ATA standard is the result of a long history of incremental technical development, which began with the original AT Attachment interface, developed for use in early PC AT equipment. The ATA interface itself evolved in several stages from Western Digital's original Integrated Drive Electronics (IDE) interface. As a result, many near-synonyms for ATA/ATAPI and its previous incarnations are still in common informal use. After the introduction of Serial ATA in 2003, the original ATA was renamed Parallel ATA, PATA for short.
Halldór
Póstar: 331
Pósturaf Halldór » Mán 13. Feb 2012 20:52
hvernig sem það er kallað hvar get ég nálgast svona stykki?
einarhr
Póstar: 2099
Staðsetning: 110 Reykjavík
Pósturaf einarhr » Mán 13. Feb 2012 21:15
Halldór skrifaði:hvernig sem það er kallað hvar get ég nálgast svona stykki?
Ætli þetta sé ekki ódýrasta lausnin sem fæst á Íslandi, http://www.tolvulistinn.is/vara/23892 hef ekki fundið svona breytistykki til sölu á Íslandi en hver veit, þetta gæti verið til í e-h versluninni á Klakanum og spurning að hringja í e-h að verslunum og spyrja.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812206002
Olafst
Póstar: 285
Skráði sig: Mán 15. Mar 2010 12:29
Pósturaf Olafst » Mán 13. Feb 2012 21:50
Er það ekki þetta? http://tl.is/vara/17003
einarhr
Póstar: 2099
Pósturaf einarhr » Mán 13. Feb 2012 22:55
Olafst skrifaði:Er það ekki þetta? http://tl.is/vara/17003
:happy
Datt ekki í hug að leyta undir ATA kapplar en þetta er málið, gj Olafst
