Mac Pro "Ruslatunnan" 12 kjarna / 64 GB RAM / 1TB SSD / Dual AMD FirePro D700 GPU
Televisionary
Póstar: 669
Pósturaf Televisionary » Mið 21. Des 2022 16:27
Spekkar:
CPU:
Processor Speed: 2.7 GHz Processor Type: 12 Core Xeon E5-2697v2
Details: The 64-bit 22-nm "Xeon E5" processor, or more specifically the "Ivy Bridge-EP" based E5-2697v2, has twelve independent "cores" each with a dedicated 256k level 2 cache and 30 MB of level 3 "Smart Cache." It also supports "Hyper-Threading" -- which "allows two threads to run simultaneously on each core" (so OS X recognizes twenty four total cores on this model, twelve real and twelve virtual) -- and "Turbo Boost" -- which "automatically boosts the processor speed based on workload" up to 3.5 GHz for this model.
GPU
The dual AMD FirePro D700 [graphics processors], each with 6 GB of GDDR5 VRAM, have 2048 stream processors, [a] 384-bit-wide memory bus, 264 GB/s memory bandwidth, and 3.5 teraflops performance."
RAM:
64GB ECC minni
Disk:
1 TB SSD
Fullir spekkar hérna: https://everymac.com/systems/apple/mac_ ... specs.html
Verð 180.000 kr. / Listaverð á þessari vél var 10.000$ USD.
Síðast breytt af Televisionary á Lau 14. Jan 2023 12:45, breytt samtals 3 sinnum.
Televisionary
Póstar: 669
Re: Mac Pro "Ruslatunnan" 12 kjarna / 128 GB RAM / 1TB SSD / Dual AMD FirePro D700 GPU
Pósturaf Televisionary » Mið 28. Des 2022 14:43
Televisionary
Póstar: 669
Re: Mac Pro "Ruslatunnan" 12 kjarna / 64 GB RAM / 1TB SSD / Dual AMD FirePro D700 GPU
Pósturaf Televisionary » Sun 22. Okt 2023 19:02
Upp, geggjuð vél. Synd að láta hana rykfalla.
