[SELT] Skjákort, MSI 280X 3GB 20.000 kr.
tobbi11
Póstar: 265
Skráði sig: Lau 18. Okt 2014 18:50
Pósturaf tobbi11 » Mið 15. Jún 2016 19:57
Til sölu MSI 280x skjákort
Graphics Processing Unit AMD Radeon™ R9 280X
Interface PCI Express x16 3.0 Boost /
Base Core Clock 1000MHz
(Boost Clock:1050MHz) (OC mode)
(Boost Clock:1020MHz) (Gaming mode)
(Boost Clock:1000MHz) (Silent mode)
Memory Size (MB) 3072 Memory Type GDDR5 Memory Interface 384 bits
Memory Clock Speed (MHz) 6000
Memory Bandwidth (GB/sec) 288
DVI Connectors DL-DVI-I x1 Max Resolution:2560 x 1600 @60 Hz
HDMI Connectors 1 (version 1.4a) Max Resolution: 3840x2160 @30 Hz 4096x2160 @24 Hz
Mini DisplayPort 2 (version 1.2) Max Resolution: 4096x2160 @ 50 Hz
Maximum Displays Up to 6 displays with the use of a DP MST Hub HDCP Support Y RAMDAC speed (MHz) 400
DirectX Version Support 12 API OpenGL Version Support 4.3 Multi-GPU Technology CrossFire
Card Dimension(mm) 269x128x34 mm Card Weight (g) 849
Power consumption (W) 250 Recommended PSU (W) 500
Power Connectors 1x6-Pin, 1x8-Pin
Verð 20.000 kr.
Síðast breytt af tobbi11 á Þri 21. Jún 2016 20:59, breytt samtals 1 sinni.
The conquest of nature is to be achieved through number and measure... and overclocking
3dmark Icelandic Records
2070s 1080ti 5700xt Vega64 1060 1050ti 1600
3dmark World record
1600+2070s
raXXar
Póstar: 2
Skráði sig: Mán 20. Jún 2016 20:41
Re: [TS] Skjákort, MSI 280X 3GB 20.000 kr.
Pósturaf raXXar » Mán 20. Jún 2016 20:46
777-4836 send me message where and when I need to come to pick up card :)
