M-Audio Project mix i/o 8 rásir með preamp hljóðkort
Höfundur - Bannaður
- Póstar: 3540
- Skráði sig: Mið 17. Feb 2010 12:58
Sælir
ég er með Til sölu M-Audio Project mix i/o 8 rásir með preamp firewire hljóðkort pci-e firewire kort fylgir með
þetta er í topp standi og er geðveikt hljóðkort á alla vegu kostaði fyrir 4 árum síðan 230þús
FEATURES
Records audio directly into Pro Tools M-Powered industry-standard format
Use with Live, Logic, Cubase, Digital Performer and SONAR with total compatibility
Assignable rotary encoders provide control of mixes, effects, and synths
FireWire control surface and 18-in x 14-out audio
interface10-bit touch-sensitive motorized moving faders
8 mic/line inputs (XLR and 1/4" TRS balanced) with switchable phantom power and signal-peak LEDs
LCD display shows full track and parameter status
Dedicated transport controls and jog/scrub wheel for seamless session flow
8 x 8 ADAT Lightpipe I/O
2 x 2 S/PDIF coaxial optical I/Os
2 stereo headphone outputs (1/4" TRS outputs)
Front-panel instrument input (1/4" TS) switchable for input one
Function LED for each channel
MIDI I/O with activity LEDs
Kensington lock port
Mackie Control
Logic Control
HUI protocols plus support for most other popular applications
Package includes:
ProjectMix I/O
1 FireWire cable (6-pin to 6-pin)
1 FireWire cable (6-pin to 4-pin)
Power supply
Ableton Live Lite 4 software CD
FireWire family driver CD
Quick Start guide
PDF manual
Get the control and connectivity you want! Order today!
SPECIFICATIONS
ProjectMix I/O
Control
8 touch-sensitive motorized channel faders
1 touch-sensitive motorized master fader
8 assignable rotary encoders and large LCD for channel or plug-in functions
record enable, select, solo and mute buttons on each channel
Channel +/- and bank +/- keys
Illuminated transport controls for record, play, stop, fast forward and rewind
Jog/scrub wheel with mode switch
Zoom key with 4 directional keys
Dedicated keys for in/out points, locate, region nudge, loop and more
A/B headphone source switch for cue auditioning
function LED display for each channel
I/O
8 analog mic/line inputs (1/4" TRS and XLR balanced) each with signal/peak indicators and mic/line switch
4 analog outputs (1/4" TRS balanced)
ADAT Lightpipe I/O
Front panel instrument input (1/4" TS) switchable for input 1
S/PDIF digital I/O
1 x 1 MIDI I/O with activity LEDs
FireWire (IEEE 1394) connectivity
Word clock I/O (BNC)
Phantom power
2 stereo headphone outputs (1/4" TRS) with independent level controls
All Pro Tools systems (MIDI control only)
Logic*
Cubase*
Ableton Live 5 or greater^
Digital Performer*^
SONAR*^
ASIO 2
GSIF 2
Core Audio
* DAW software version must support Mackie Control, Logic Control or HUI protocol.
^Support provided after product launch via free downloadable firmware upgrade; see this page and Support>Drivers section soon for availability.
Dimensions: 25-2/5"W x 22"D x 9-1/10"H
Weight: 15.9 lbs.
Verðhugmynd 80-90þús miðað við hvað það kostar notað að utan en það fylgir með pci-e firewire kort og löng firewire snúra
FEATURES
Mackie Control
Logic Control
Package includes:
ProjectMix I/O
Power supply
Quick Start guide
PDF manual
SPECIFICATIONS
ProjectMix I/O
Control
I/O
ADAT Lightpipe I/O
S/PDIF digital I/O
Phantom power
Logic*
Cubase*
Digital Performer*^
SONAR*^
ASIO 2
GSIF 2
Core Audio
Weight: 15.9 lbs.
Höfundur - Bannaður
- Póstar: 3540
Re: M-Audio Project mix i/o 8 rásir með preamp hljóðkort
- Póstar: 2103
- Skráði sig: Fim 24. Jún 2010 01:58
- Staðsetning: Heima
Sexý
i7-11700KF|64gb(2x32gb)ddr4|1060-6gb|1tb Samsung 980 Pro nvme m.2|1tb Samsung 860 Evo sata ssd|Corsair HX1200|
Höfundur - Bannaður
- Póstar: 3540
Mjög svo:)
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
uppp endilega bjóðið
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
Fyrir þá sem eru kannski ekki alveg inni í þessum geira en langar í þetta kort þá er þetta verðbil bara mjög fair.
Kostaboð fyrir t.d þá sem vilja taka upp demo, það eru nefnilega bara ágætis preampar í þessu korti og góð AD breyta!
Höfundur - Bannaður
- Póstar: 3540
tdog skrifaði:Fyrir þá sem eru kannski ekki alveg inni í þessum geira en langar í þetta kort þá er þetta verðbil bara mjög fair.
Takk fyrir þetta. þetta er alveg hárétt, þetta er rosalega gott miðað við verð og maður er að fá helling fyrir peninginn, ég notaði þetta í gegnum Pro Tools nám hja Berklee Collage of Music og er búinn að taka helling upp á þessu og þetta er mega græja
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
vantar engum geðveikt hljóðkort, ég er buinn að vera nota þetta í leikjaspilun seinustu mánuði og þetta er miklu betra en allt annað sem er í boði en er orðið fyrir mér og þarf að losna við þetta
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
uppp
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
fer á 70þús ef þetta fer bráðlega
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
Höfundur - Bannaður
- Póstar: 3540
