CM690 - Logitech X-530 - NZXT sentry 2 - 3x140mm Viftur
Gunnar
Póstar: 2377
Staðsetning: 105 Reykjavík
Pósturaf Gunnar » Fim 01. Des 2011 13:25
CoolerMaster 690 - SELT
Available Color - Black
Dimension (W / H / D) (W) 213 x (H) 482 x (D) 525 mm
(W) 8.38 x (H) 18.98 x (D) 20.67 inch
Weight Net Weight: 9.8 kg / 21 lb
Gross Weight: 11.5 kg / 25.4 lb
Material Chassis: SECC, Bezel: Metal mesh + ABS
Motherboards ATX / Micro-ATX
5.25" Drive Bay 5 Exposed
(without the use of exposed 3.5 inch Drive Bay)
4 Exposed
(with the use of 3.5 inch Drive Bay)
3.5" Drive Bay 5 Hidden
1 Exposed (converted from one 5.25 inch Drive Bay)
I/O Panel USB 2.0 x 2, IEEE 1394 x 1, MIC x 1, eSATA x 1,
SPK x 1 (support HD Audio)
Cooling System Front: 120 x 25 mm Blue LED fan x 1 / 1200 RPM / 21 dBA
Rear: 120 x 25 mm fan x 1 / 1200 RPM / 21 dBA
Top: 120 or 140 mm fan x 2 (optional)
Bottom: 120 x 25 mm fan x 1 (optional)
Left: 120 x 25 mm fan x 2 (one is optional)
Expansion Slots 7
Power Supply Standard ATX PS2/ EPS 12V (optional)
Myndband um turninn frá framleiðanda.
http://www.youtube.com/watch?v=LZLvtMnf ... r_embedded
Turninn er tómur og kemur með eitthvað af fylgihlutum.
Aðeins er ein rispa á honum á vinstra horninun að framan.
Fleirri upplýsingar: http://www.coolermaster.com/product.php?product_id=2908
keypti hann nýjann en ábyrgð er runnin út.
Verðhugmynd: 12.000kr
3x 14cm TurboFan frá Thermaltake
140 x 140 x 25 mm TurboFan, bullet-shaped fan hub, for improved air flow
Connects directly to Power Supply
Application for DC 12V
UL, CE approved
Fan Dimension 140 x 140 x 25 mm
Fan Speed 1000 ± 200 RPM
Fan Speed Control N/A
LED Color N/A
Bearing Type Sleeve
Noise Level 16 dBA
Max. Air Flow 50 CFM
Max. Air Pressure 0.3MM-H2O
Power Connector 4-pin
Rated Voltage 12V
Started Voltage 6V
Rated Current 0.3A
Static Pressure
Operation Temperature
Power Input 3.6W
MTBF 30000 Hours
Weight 140 g
Verslaðar á svipuðum tíma og turninn og passa þær vel í hann.(mæli með þeim í hann)
fann þær ekki til sölu hér. keypt í computer.is minnir mig.
Verðhugmynd fyrir allar: 5000kr
Logitech X-530 --- SELT til tengdó
Technical Specifications
Total FTC power: 70 watts RMS
Satellites:
Left/right: 7.4 watts RMS x 2 (into 4 ohms, @ 1 kHz, @ 10% THD)
Center: 15.5 watts RMS (into 4 ohms, @ 1 kHz, @ 10% THD)
Rear left/right: 7.4 watts RMS x 2 (into 4 ohms, @ 1 kHz, @ 10% THD)
Subwoofer: 25 watts RMS (into 4 ohms, @ 100 Hz, @ 10% THD)
Total peak power: 140 watts
Frequency response: 40 Hz–20 kHz
Drivers:
Satellites: Two 5 cm drivers per satellite
Subwoofer: 13.3 cm ported driver
Speaker dimensions (H x W x D, cm):
Satellites: 20.3 x 6.4 x 7.6
Subwoofer: 22.9 x 15.2 x 23.5
Signal-to-noise ratio: >96 dB
System Compatibility
PC or Mac
CD player
Digital (MP3) music player
DVD player
PlayStation®, PlayStation®2, PLAYSTATION®3 (with game console adapter, not included)
Xbox®, Xbox 360™ (with game console adapter, not included)
Kerfið virkar fullkomlega þegar ég notaði það seinast og það er pakkað saman ofaní kassa.
Nokkrar rifur eru á hlífunum en ekkert sem skemmir hljóðið og sést varla.
fleirri upplýsingar: http://www.logitech.com/en-roeu/speaker ... evices/211
keypti kerfið á vaktinni.
Verðhugmynd: 15.000kr
NZXT Sentry 2 --- SELD
Features
• Touch screen interface
• Five fan control through an intuitive interface
• Ultra fast selection and response time
• Display temperatures in both F and C
• Light switch turns off the meter when sleeping
• Automatic and manual modes of control
• Full compatibility with all types of fans using voltage control
• With a maximum of 10 Watts per channel, the Sentry 2 will support almost all high end fans
• Tuned accuracy with only a tolerance of one degree
• Sound alarm to alert when the temperature is over
• Stored settings, the Sentry keeps your settings even after power off
Fan Channel 5
Max watt per channel 10W
Temperature Module Channel 5
Temperature Range 0 ~ 120℃
Measurement Frequency Every 2 Seconds
Temperature Alarm Range 30℃ to 90℃
(AUTO) Min 40%, Under 0-25℃,fan RPM 40%
(MANUAL) Min 40%
Screen Size 4.63 inches
Viftustýringin kemur í uppranalega boxi með flestöllu í.
Plastið er enþá framaná svo engar rispur eru á skjánum.
keypti stýringuna nýja og getur fylgt með 4 mánaða ábyrgð
Verðhugmynd: 4000kr SELD
Ef eitthvað vantar eða of há verðlagning hjá mér endilega bendið mér á það i pm svo ég geti brugðist við og lækkað. eða á þráðin ef þið viljið það frekar.
Tók bara fyrsta verðið sem ég fann og lækkaði það um sirka 40%
Gef mér rétt til að hætta við sölu hvenær sem ég vill.
Síðast breytt af Gunnar á Mán 23. Jan 2012 18:48, breytt samtals 5 sinnum.
Gunnar
Póstar: 2377
Re: CM690 - Logitech X-530 - NZXT sentry 2 - 3x140mm Viftur
Pósturaf Gunnar » Fös 02. Des 2011 14:07
búmp
Gunnar
Póstar: 2377
Pósturaf Gunnar » Sun 04. Des 2011 00:52
Bump - viftustýringin farin a uppsettu verdi.
Gunnar
Póstar: 2377
Pósturaf Gunnar » Sun 04. Des 2011 20:32
Bump.
Gunnar
Póstar: 2377
Pósturaf Gunnar » Þri 06. Des 2011 01:37
Bump
Gunnar
Póstar: 2377
Pósturaf Gunnar » Mið 07. Des 2011 14:28
bump
Gunnar
Póstar: 2377
Pósturaf Gunnar » Fim 08. Des 2011 14:24
kaupakaupakaupa
Póstar: 6833
Pósturaf Viktor » Fim 08. Des 2011 19:43
Þessi auglýsing fær 5 stjörnur.
MyndMyndMyndMyndMynd
Gunnar
Póstar: 2377
Pósturaf Gunnar » Fös 09. Des 2011 11:13
Sallarólegur skrifaði:Þessi auglýsing fær 5 stjörnur.
þakka þér =D>
Gunnar
Póstar: 2377
Pósturaf Gunnar » Lau 10. Des 2011 22:56
uppuppuppuppuppuppuppuppuppuppuppuppupp
Gunnar
Póstar: 2377
Pósturaf Gunnar » Mán 12. Des 2011 12:05
Bara minna a mig!!
Gunnar
Póstar: 2377
Pósturaf Gunnar » Þri 13. Des 2011 15:48
Gunnar
Póstar: 2377
Pósturaf Gunnar » Sun 18. Des 2011 19:22
bump
Gunnar
Póstar: 2377
Pósturaf Gunnar » Þri 27. Des 2011 22:26
uppppppppppppp
Gunnar
Póstar: 2377
Pósturaf Gunnar » Mið 28. Des 2011 18:11
comon man, i need money man!!! :lol:
Gunnar
Póstar: 2377
Pósturaf Gunnar » Mán 02. Jan 2012 17:13
bumps
vantar engum góðann turn sem kælir vél? :O
steinthor95
Póstar: 234
Skráði sig: Þri 15. Nóv 2011 15:49
Staðsetning: Akureyri og Þingeyjarsveit
Pósturaf steinthor95 » Mán 02. Jan 2012 18:34
ég er að spá í hvernig þessi NZXT Sentry 2 viftustýring er tengd, er hún tengd bara beint frá aflgjafanum og úr henni í allar viftur? (er að pæla í þessu þar sem móðurborðið mitt styður bara 2 kassaviftur og mig langar í fleiri :D)
Tölvan: Gigabyte P67X-UD3 - Intel Core i5-2500K - corsair H100i - Asus strix Gtx 970 4GB - Mushkin 16GB DDR3 1333MHz - 4 TB HDD - 240 gb Kingston SSD - Thermaltake 850w - Corsair 550D
Jaðartæki: 2x 24" BenQ LED - Razer Blackwidow - Bose Quietcomfort 25 - Logitech G602
Gunnar
Póstar: 2377
Pósturaf Gunnar » Mán 02. Jan 2012 18:51
steinthor95 skrifaði:ég er að spá í hvernig þessi NZXT Sentry 2 viftustýring er tengd, er hún tengd bara beint frá aflgjafanum og úr henni í allar viftur? (er að pæla í þessu þar sem móðurborðið mitt styður bara 2 kassaviftur og mig langar í fleiri :D)
Molex tengi úr aflgjafanum fer í molex tengi á viftustýringunni og svo er 3 pinna eða molex í vifturnar. annars er viftustýringin seld.
svo eru 5 hitaskynjarar sem þú getur sett þar sem vifturnar eru að kæla.
steinthor95
Póstar: 234
Pósturaf steinthor95 » Mán 02. Jan 2012 18:53
Gunnar skrifaði:
Já vissi að hún væri seld en mig vantaði bara þessar upplýsingar, takk fyrir :happy
Gunnar
Póstar: 2377
Pósturaf Gunnar » Mán 02. Jan 2012 20:17
Gunnar skrifaði:
lítið mál. :)
Gunnar
Póstar: 2377
Pósturaf Gunnar » Fös 06. Jan 2012 00:57
bump
Gunnar
Póstar: 2377
Pósturaf Gunnar » Mið 11. Jan 2012 13:00
endilega bjóðið hvað ykkur finnst samgjarnt. :)
Noristori
Póstar: 9
Skráði sig: Fim 12. Jan 2012 16:19
Pósturaf Noristori » Fim 12. Jan 2012 17:23
Lýst ágætlega á þennan kassa en myndiru láta hann á 9,000 kr? og hvar á landinu er kassin? :)
Gunnar
Póstar: 2377
Pósturaf Gunnar » Fim 12. Jan 2012 17:32
Noristori skrifaði:Lýst ágætlega á þennan kassa en myndiru láta hann á 9,000 kr? og hvar á landinu er kassin? :)
http://tolvutaekni.is/product_info.php? ... ts_id=1837 kostar 19 þúsund nýr.
Til í 10 þúsund. annars er hann staðsettur í 109 rvk. ekkert mál fyrir mig að senda með pósti.
Póstar: 6585
Pósturaf worghal » Fim 12. Jan 2012 17:38
Gunnar skrifaði:
http://tl.is/vara/23971
þetta er turninn sem þú auglýsir, hinn er CM 690 II Advanced.
