SELT: LCD Skjár: Nýr 24" Philips LCD 1920x1200
Höfundur - Fiktari
- Póstar: 80
- Skráði sig: Fim 12. Nóv 2009 02:30
Er með glænýjann 24" 1920x1200 Philips Brilliance skjá. Hann er í kassanum og er bara búið að taka hann upp úr kassanum til að athuga hvort hann virki ekki pottþétt.
Heiti: Philips Brilliance LCD widescreen monitor 240SW9FS/00 24" wide WUXGA
Týpunúmer: 240SW9FS/00
Bæklingur: http://www.p4c.philips.com/files/2/240sw9fs_00/240sw9fs_00_pss_aen.pdf
Nánar: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=240SW9FS/00&slg=en&scy=CZ
Verð tilboð !
Sigurður
siggibj (hjá) gmail.com
840-1220
Eftirfarandi upplýsingar eru teknar úr PDF bæklingnum að ofan:
Picture/Display
• LCD panel type: TFT-LCD
• Panel Size: 24" / 61.1 cm
• Aspect ratio: 16:10
• Pixel pitch: 0.270 x 0.270 mm
• Brightness: 300 cd/m²
• SmartContrast ratio (dynamic): 10000:1
• Contrast ratio (typical): 1000 : 1
• Viewing angle: 160º (H) / 160º (V), @ C/R > 10
• Picture enhancement: SmartImage
• Response time (typical): 5 ms
• Optimum Resolution: 1920 x 1200 @ 60Hz
• Display colors: 16.7 M
• Horizontal Scanning Frequency: 24 - 94 KHz
• Vertical Scanning Frequency: 48 - 85 Hz
• sRGB
Connectivity
• Signal Input: VGA (Analog ), DVI-D
• Sync Input: Composite Sync, Separate Sync, Sync on Green
Convenience
• User convenience: SmartControl II, SmartManage enabled, Picture format selection, On-screen Display
• Monitor Controls: Auto (Back), Brightness (Up), Input (Down), Menu (OK), Power On/Off, SmartImage
• OSD Languages: English, French, German, Italian, Russian, Simplified Chinese, Spanish, Portuguese
• Regulatory Approvals: CE Mark, Energy Star, FCC Class B, SEMKO, TCO '03, TÜV/GS, TÜV Ergo, UL/cUL
• Plug & Play Compatibility: DDC/CI, sRGB, Windows 98, Windows 2000, Windows XP, Windows Vista, Mac OS X
• Other convenience: Kensington lock compatible
• Tilt: -5° to 20°
• VESA Mount: 100 x 100 mm
Power
• Consumption (On mode): < 65 W (typical)
• Consumption (economy mode): 37 W
• Consumption (Off Mode): < 0.8 W
• Power LED indicator: Operation - Blue, Stand by/sleep -blue(blinking)
• Power supply: Built-in, 100-240VAC, 50/60Hz
• Complies with: Energy Star
Dimensions
• Set dimensions with stand (W x H x D): 559 x 494 x 220 mm
• Set dimensions with stand in inch (W x H x D): 22.0 x 19.45 x 86.6 inch
• Set dimensions (W x H x D): 559 x 381 x 75 mm
• Set dimensions in inch (W x H x D): 22.0 x 15.0 x 2.95 inch
• Relative humidity: 20% - 80%
• MTBF: 50,000 hrs
• Box dimensions (W x H x D): 638 x 546 x 188 mm
• Box dimensions in inch (W x H x D): 25.11 x 21.5 x 7.4 inch
• Product weight (+stand): 5.7 kg
• Product weight (+stand) (lb): 12.57 lb
• Weight incl. Packaging: 7.7 kg
• Weight incl. Packaging (lb): 16.96
• Temperature range (operation): 0°C to 40°C
• Temperature range (storage): -20°C to 60°C
Verð tilboð !
Sigurður
840-1220
Picture/Display
• sRGB
Connectivity
Convenience
• Tilt: -5° to 20°
Power
Dimensions
• MTBF: 50,000 hrs
Síðast breytt af sigurdurbj á Lau 21. Nóv 2009 20:36, breytt samtals 2 sinnum.
- Póstar: 1832
- Skráði sig: Sun 08. Jún 2008 01:18
- Staða: Tengdur
Re: LCD Skjár: Nýr 24" Philips LCD 1920x1200 (ónotaður í kassa)
stolinn?
Sorglegt hve fljótir menn eru að koma með dónalegar ásakanir. Varla myndi maðurinn skrá sig hér með nafni og gefa upp síma sem skráður er á hann í símaskrá ef hann væri að koma úr innbrotaferð næturinnar?
Að sjálfsögðu ekkert að því að spyrja um nótu ef menn eru fyrir alvöru að hugsa um að bjóða í gripinn til þess að staðfesta ábyrgð og aldur, en fyrsta svarið sem maðurinn fékk er argasti dónaskapur.
Held það segi meira um hann Nariur heldur en seljandann að hann skuli stökkva strax á þessa ályktun að varan sé stolin. Kannski hefur hann aldrei eignast vöru í þessum verðflokk án þess að verða sér útum hana á óheiðarlegan hátt
Höfundur - Fiktari
- Póstar: 80
- Hann er ekki stolinn
- Ég er með nótu, en hann var keyptur erlendis og ég hef bara ekki pláss fyrir hann og því sel ég hann. Skilst að það eigi að vera hægt að fá ábygðarviðgerðir á honum á íslandi ef eitthvað kemur upp en hef það þó ekki staðfest.
- Póstar: 1832
- Staða: Tengdur
hvað er að fólki? þetta var spurning, ekki ásökun... þetta leit nokkuð grunsamlega út, fyrsti pósturinn hans, skjárinn glænýr og... eiginlega allar aðstæður sem bentu á að það væri möguleiki.
Ég hefði kannski átt að orða þetta öðruvísi, ég biðst afsökunar.
maður hefur nú séð verri hluti hérna
Höfundur - Fiktari
- Póstar: 80
- Fiktari
- Póstar: 66
- Skráði sig: Mán 13. Apr 2009 23:16
Nariur skrifaði:hvað er að fólki? þetta var spurning, ekki ásökun...
Hehe... þetta er eins og spurningin "Ertu hættur að lemja konuna þína?" sem gefur allt í skyn og skilur lítið svigrúm eftir fyrir svar...
- Póstar: 1832
- Staða: Tengdur
hann svaraði spurningunni rétt, jafngildi ég hef aldrei lamið konuna mína
Höfundur - Fiktari
- Póstar: 80
komasvo, bjóða, hæsta boð komið í 43þús
Höfundur - Fiktari
- Póstar: 80
- Póstar: 3337
- Skráði sig: Mið 08. Okt 2008 22:07
- Staðsetning: /dev/null
Ég býð Acer 22" og 10.000 upp í.
- Nýliði
- Póstar: 7
- Skráði sig: Fim 12. Apr 2007 21:05
- Staðsetning: dalvik
skipta á Samsung 2253BW og 5000 þús upp í ??
Höfundur - Fiktari
- Póstar: 80
hef ekki áhuga á 22" skjá. takk samt
Höfundur - Fiktari
- Póstar: 80
Ennþá til sölu! Góður skjár í leit að traustum eiganda.
- Bannaður
- Póstar: 54
- Skráði sig: Fös 12. Jún 2009 23:23
veit að þú hefur ekki áhuga á 22'' en...ég er með 22'' Acer (AL2216W) og 10þús á milli???
Amd Dual Core 5200+ @2.6 ghz, Msi-K9N6SGM-V, Msi Nvidia Geforce 250GTS 512MB. 2x2GB 800Mhz Corsair Ram, 22'' Acer wide.
Höfundur - Fiktari
- Póstar: 80
Chuck_Norris skrifaði:veit að þú hefur ekki áhuga á 22'' en...ég er með 22'' Acer (AL2216W) og 10þús á milli???
nei, takk samt
- Bannaður
- Póstar: 54
ok, flott 15 þús á milli eða verðhugmynd? hvað er þessi skjár metin á???
- Póstar: 3337
Chuck_Norris skrifaði:ok, flott 15 þús á milli eða verðhugmynd? hvað er þessi skjár metin á???
Ég held hann vilji bara peninginn, ekki 22" í staðinn.
- Bannaður
- Póstar: 54
ok, ekkert mál, hvað viltu fá fyrir skjáinn , ekki vera hræddur að nefna verð :S
- Bannaður
- Póstar: 95
- Skráði sig: Þri 28. Apr 2009 15:00
- Staðsetning: Jörðin
Uhm. Þegar þú vissir að hann hefði ekki áhuga á 22" skjám afhverju bauðstu honum það þá samt?
ASRock-P43D2. Intel core 2 duo e7400(3ghz, 3mb cache). Mushkin(4gb DDR2 800mhz). Force3D ATI HD5770(1GB ddr5, 4800mhz memory clock). HDD(500GB 7200rpm 16mb cache, 160GB 5400rpm, 80gb flakkari. Power supply: Tacens 520w. Case: Tacens Victoria II.
Höfundur - Fiktari
- Póstar: 80
Chuck_Norris skrifaði:ok, ekkert mál, hvað viltu fá fyrir skjáinn , ekki vera hræddur að nefna verð :S
Ég hefði viljað fá um 45-50þús fyrir skjáinn. sambærilegur skjár kostar nýr um 70þús út úr búð alveg jafn nýr og þessi...
- Bannaður
- Póstar: 54
já sæll! farðu og seldu pólskar mellur fyrir 200.000kr. fyrir 5 min í staðinn!
- Póstar: 3086
- Skráði sig: Fös 30. Nóv 2007 19:06
sigurdurbj skrifaði:Chuck_Norris skrifaði:ok, ekkert mál, hvað viltu fá fyrir skjáinn , ekki vera hræddur að nefna verð :S
Já EN sá skjár er þá í ábyrgð en ekki þessi.
Veistu hvað það kostar mikið að gera við þetta ef þetta bilar ?
